Looking 4ward to the step by step guide with pics , be a big help for members wishing to do retrofit at a later dateDone test run with 8p mirror for puddle light. Hardest part was figuring out how to run wire but sussed it.
Next job fitting reckon full day to do will post pics when done.
Sent from my SM-G935F using Tapatalk
No worries will do I always pick hardest ones to do lol. Be next week now back on nights.Looking 4ward to the step by step guide with pics , be a big help for members wishing to do retrofit at a later date
checked mine today and at -3.0
Was that straight after a cambelt change? Wonder how you reset this value? Hmmm
Pics pics pic'sJust fitted one oft he cheapo ebay rear wiper arms. Nice little mod for £4! my rear washer wasn't working either but followed the advice and cleaned the nozzle with a pin whilst I had it out, also gave it a little soak in some hot soapy water which brought a load of **** out and now it's working again. Dead easy mod really and cost less than a replacment OEM wiper blade
Wasn't going to bother because the car isn't clean....Pics pics pic's
Totally agreeWasn't going to bother because the car isn't clean....
Update after a 12hr night shift decided to do this mod wing mirror puddle lights. started at 8.30am finished 4.30pm and I over the moon with the results pics to follow. Need sleepNo worries will do I always pick hardest ones to do lol. Be next week now back on nights.
The pics and the How To should have been done and posted b4 sleep as plenty off time for that on your days offUpdate after a 12hr night shift decided to do this mod wing mirror puddle lights. started at 8.30am finished 4.30pm and I over the moon with the results pics to follow. Need sleep
Ok here s a pic just taken. Will so full write up tomorrow guysThe pics and the How To should have been done and posted b4 sleep as plenty off time for that on your days off
Was honestly looling for the Batman logo but guess the white light look will just av to do . Nice JobOk here s a pic just taken. Will so full write up tomorrow guys
Ha ha ha ha ha ha.Was honestly looling for the Batman logo but guess the white light look will just av to do . Nice Job
Never knew @t8ups did led's to change the colour off Cats need to get some off those for my niece so she can light hers up for XmasLooking forward to seeing that one!
I've been meaning to post for a while... can't remember when I started this stuff but done a few little bits over the summer.
First I finally got around to debadging and putting pressed plates on:
View attachment 168486 View attachment 168483
Fitted full puddle lights, warning lights and front footwells thanks to @RobinA3... not thanks to the cat that kept knocking the door card over.
View attachment 168488 View attachment 168489
Then upgraded straight to LED's to match the rest of the interior thanks to @t8ups
Finally finished off the non smokers pack with the flip top lid and 12v usb that sits flush under it.
Cleaned up the interior, and got a few good pics on a trip to the lakes.
Next job is getting a headunit!
Here you go ( 8P0 863 387A6 PS ). Courtesty off @samuelh_888Nice mods, have you got the part number for the flip top lighter replacement part??
Hi mate got my tpms installed with badly written instructions. It worked for a short while then it stopped working came up fail so I reinstalled went to set it for each tyre pressure it came up different and now won't work. Is there a way to reset the unit ?i set the tyres to those pressures recently, so yeah its accurate. temperature im not sure about tbh, unless the temp inside the tyre is warmer than outside temp even if the cars been standing.
I uninstalled it re-installed it's working now but there's another icon not on my screen a orange one. It controls thisWhich apk did you use? I used the one with the alarm mentioned in the title and it's been working stable since I fitted them
Not sure what you mean. It's working now., buy somethings not on your screen?I uninstalled it re-installed it's working now but there's another icon not on my screen a orange one. It controls this
There's a blue symbol that brings up tyre pressures and temp. Then there's a orange symbol that brings up the screen in the pic aboveNot sure what you mean. It's working now., buy somethings not on your screen?
Im not using that apk, so mine is different. on the USB stick they sent there should be an apk with alarm in the title. Use that oneThere's a blue symbol that brings up tyre pressures and temp. Then there's a orange symbol that brings up the screen in the pic above
I used the one on usb stick. Installed all of them. Except the Japanese fileIm not using that apk, so mine is different. on the USB stick they sent there should be an apk with alarm in the title. Use that one
Thanks mate just wished they got somone to write clear instructions lolWhy would you install all of them lol.
The instructions they gave weren't clear at all but basically you only need to install one of the files on that USB stick, and I can vouch for the one that says alarm.
Uninstall any of the tpms apps on your unit, unplug the receiver, install the one that says alarm and try again
Edit- reread your post and I understand now. If you installed more than one tpms app, only one can access the receiver at a time and show pressures etc.by having more than one app, you've got redundant apps installed that's why one works and the other won't. Uninstall them, install only one and problem sorted
Nice job that.Received my Steering wheel back from Jack retrimmed ( you'd decide) but me I think an excellent job done and very glad I listen to a member on here about getting a certain bit extended .
Plus took the plunge and got those Fan Washer Jets ( @mechanic69 Ur off the hook lol ) good quality , easy to fit and bonus I now know I have heated jets so on the whole a good day had .
Hi yeah I have pics to put up and a guide. But some of the pics didn't come out. I will sort tomorrow.Is there a guide you used for this? Really interested in doing it to mine, always annoyed me that there were no puddle lights.
Sorry mate I commented on wrong post. But I did mines I have a write up somewhere.Hi yeah I have pics to put up and a guide. But some of the pics didn't come out. I will sort tomorrow.
Yes full guide here : https://www.audi-sport.net/xf/threads/my-diy-guide-for-retro-fitting-puddle-lights.58244/
Hardest part is cutting the plastic holes in the door card for the light to sit.
Contact @RobinA3 if you want the lights, he makes the full looms ready to plug and play. They look fully OEM, highly recommend.
