  2. Dismiss Notice
Vcds print out. Can anyone help?
pedro61163 Feb 27, 2020
  1. pedro61163
    pedro61163 Active Member
    260
    60
    Got a friend to do a vcds printout tonight. It won't connect with passenger door.
    Thursday,27,February,2020,19:35:43:34536
    VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64
    VCDS Version: 19.6.2.2 (x64)
    Data version: 20200210 DS308.0
    www.Ross-Tech.com
    VIN: WAUZZZ8V3DA013274 License Plate: PETE
    Mileage: 90595km-56293mi Repair Order:
    Chassis Type: 8V-AU37 (5Q0)
    Scan: 01 03 08 09 10 15 16 17 19 42 44 52 55 5F
    VIN: WAUZZZ8V3DA013274 Mileage: 90595km-56293miles
    01-Engine -- Status: OK 0000
    03-ABS Brakes -- Status: OK 0000
    08-Auto HVAC -- Status: OK 0000
    09-Cent. Elect. -- Status: Malfunction 0010
    10-Park/Steer Assist -- Status: OK 0000
    15-Airbags -- Status: Malfunction 0010
    16-Steering wheel -- Status: OK 0000
    17-Instruments -- Status: Malfunction 0010
    19-CAN Gateway -- Status: Malfunction 0010
    42-Door Elect, Driver -- Status: OK 0000
    44-Steering Assist -- Status: OK 0000
    52-Door Elect, Pass. -- Status: Malfunction 0010
    55-Headlight Range -- Status: OK 0000
    5F-Information Electr. -- Status: OK 0000
    Address 01: Engine (J623-CRBC) Labels:. 04L-907-309-V1.clb
    Part No SW: 04L 906 021 DS HW: 04L 907 309 D
    Component: R4 2,0L EDC H21 4941
    Revision: 83H21---
    Coding: 0A190012032501082000
    Shop #: WSC 34563 000 1048576
    ASAM Dataset: EV_ECM20TDI01104L906021DS 002008
    ROD: EV_ECM20TDI01104L906021DS_002.rod
    VCID: 79F2257FF85FBA87E2-802C
    No fault code found.
    Readiness: 0 0 0 0 0
    Address 03: ABS Brakes (J104) Labels: 5Q0-907-379-IPB-V1.clb
    Part No SW: 5Q0 907 379 AC HW: 5Q0 907 379 D
    Component: ESC H75 0437
    Revision: 00000000 Serial number:
    Coding: 10F18AA220210A6F0179060701C7290851045080608094F20279003485
    ASAM Dataset: EV_Brake1UDSContiMK100IPB 008020
    ROD: EV_Brake1UDSContiMK100IPB_008_VW37.rod
    VCID: 7DFA316FEC7786A7CE-8028
    Address 08: Auto HVAC (E87) Labels:| 8V0-820-043.clb
    Part No SW: 8V0 820 043 A HW: 8V0 820 043 A
    Component: AC Automat H11 0031
    Revision: 20017000 Serial number: 00000000017631
    Coding: 00100114002000011000000000001100
    Shop #: WSC 06314 790 00021
    ASAM Dataset: EV_AirCondiFrontVaAU37X 008016
    ROD: EV_AirCondiFrontVaAU37X.rod
    VCID: 3064D85B6BA5BBCF15-8064
    Relative humidity sensor in fresh air intake duct:
    Subsystem 1 - Part No SW: 4H0 907 658 HW: 4H0 907 658
    Component: AQ_Hum_Sensor H03 0003
    Serial number: 76784D46000000000001
    Address 09: Cent. Elect. (J519) Labels:| 5Q0-937-08X-HV1.clb
    Part No SW: 5Q0 937 084 Q HW: 5Q0 937 084 Q
    Component: BCM MQBAB H H14 0106
    Serial number: 00011227900964
    Coding: 00001842C041205317A44004F10407000000000000000000000000000000
    Shop #: WSC 00000 000 00000
    ASAM Dataset: EV_BCMCONTI 010001
    ROD: EV_BCMBOSCH_010.rod
    VCID: 46889E83F921057FDF-8012
    Control Unit For Wiper Motor:
    Subsystem 1 - Part No SW: 8V2 955 119 A HW: 8V2 955 119 Labels: 5QX-955-119-V1.CLB
    Component: WWS370 120620 041 0580
    Serial number: 120808045101
    Coding: 0A47F7
    Sensor For Anti Theft Alarm System:
    Subsystem 2 - Part No SW: 8V0 951 177 HW: 5Q0 951 172
    Component: Sensor, DWA 005 0313
    Serial number: 000000000ZY122352LFJ
    Alarm horn:
    Subsystem 3 - Part No SW: 5Q0 951 605 HW: 5Q0 951 605
    Component: Sirene, DWA 004 0311
    Serial number: 00000000000055148801
    10 Faults Found:
    9738 - Bulb for Left Parking Lamp
    B12E8 15 [009] - Open or Short to Plus
    Confirmed - Tested Since Memory Clear
    Freeze Frame:
    Fault Status: 00000001
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 180
    Mileage: 90411 km
    Date: 2020.02.21
    Time: 16:49:02
    9994 - Bulb for Right Parking Lamp
    B12E9 15 [009] - Open or Short to Plus
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 180
    Mileage: 90411 km
    Date: 2020.02.21
    Time: 16:49:02
    197128 - Lock Module for Central Locking; Rear Left
    B12DB 29 [009] - Signal Implausible
    Freeze Frame:
    Fault Priority: 4
    Fault Frequency: 1
    Reset counter: 180
    Mileage: 90411 km
    Date: 2020.02.22
    Time: 12:41:24
    197132 - Lock Module for Central Locking; Rear Left
    B12DB 01 [009] - Electrical Failure
    Freeze Frame:
    Fault Priority: 4
    Fault Frequency: 1
    Reset counter: 180
    Mileage: 90411 km
    Date: 2020.02.21
    Time: 16:59:35
    197384 - Lock Module for Central Locking; Rear Right
    B12DC 29 [009] - Signal Implausible
    Freeze Frame:
    Fault Priority: 4
    Fault Frequency: 1
    Reset counter: 180
    Mileage: 90411 km
    Date: 2020.02.22
    Time: 12:41:24
    197388 - Lock Module for Central Locking; Rear Right
    B12DC 01 [009] - Electrical Failure
    Freeze Frame:
    Fault Priority: 4
    Fault Frequency: 1
    Reset counter: 180
    Mileage: 90411 km
    Date: 2020.02.21
    Time: 16:59:35
    197644 - Control Circuit for Fuel Tank Flap
    B1263 01 [009] - Electrical Failure
    Freeze Frame:
    Fault Priority: 4
    Fault Frequency: 1
    Reset counter: 180
    Mileage: 90411 km
    Date: 2020.02.21
    Time: 17:07:42
    555797 - Databus
    U1121 00 [009] - Missing Message
    [New feature! Extended UDS fault detail is only supported by current gen. interfaces]
    Freeze Frame:
    Fault Priority: 6
    Fault Frequency: 1
    Reset counter: 180
    Mileage: 90411 km
    Date: 2020.02.21
    Time: 16:49:02
    13697024 - Component Protection
    U1100 00 [009] - No Basic Setting
    Freeze Frame:
    Fault Priority: 4
    Fault Frequency: 1
    Reset counter: 180
    Mileage: 90411 km
    Date: 2020.02.21
    Time: 16:49:02
    15361024 - Component Protection
    U1101 00 [009] - Active
    Freeze Frame:
    Fault Priority: 4
    Fault Frequency: 1
    Reset counter: 180
    Mileage: 90411 km
    Date: 2020.02.21
    Time: 16:49:02
    Address 10: Park/Steer Assist (J791) Labels:| 5Q0-919-283.clb
    Part No SW: 5Q0 919 283 A HW: 5Q0 919 283
    Component: PARKHILFE 4K 009 0026
    Revision: -------- Serial number: 60831225704183
    Coding: 0000050001
    ASAM Dataset: EV_EPHVA14AU3700000 002015
    ROD: EV_EPHVA14AU3700000_002_VW37.rod
    VCID: 3776E3478ECB6CF754-8062
    Address 15: Airbags (J234) Labels:| 5Q0-959-655.clb
    Part No SW: 5Q0 959 655 L HW: 5Q0 959 655 L
    Component: AirbagVW20 009 0349
    Serial number: 003GER009ZHZ
    Coding: 98CCC0000C0000005C5400CA00C800000065
    ASAM Dataset: EV_AirbaVW20SMEVW37X 002126
    ROD: EV_AirbaVW20SMEVW37X.rod
    VCID: 499295BFE83FEA0732-801C
    Side Sensor Driver Front:
    Subsystem 1 - Part No SW: ----------- HW: 480 000 810 12
    Component: SideSensor_Df 001 0887
    Serial number: 357670000002CAC4EB07
    Coding: 2D2D2D
    Side Sensor Passenger Front:
    Subsystem 2 - Part No SW: ----------- HW: 480 000 810 12
    Component: SideSensor_Pf 001 0887
    Serial number: 35867000000D9939EB0B
    Coding: 2D2D2D
    Side Sensor Driver Rear:
    Subsystem 3 - Part No SW: ----------- HW: 480 401 809 12
    Component: SideSensor_Dr 001 6149
    Serial number: 3516502AB0D19C31C37I
    Coding: 2D2D2D
    Side Sensor Passenger Rear:
    Subsystem 4 - Part No SW: ----------- HW: 480 401 809 12
    Component: SideSensor_Pr 001 6149
    Serial number: 3526502990CD5EB1C39Z
    Coding: 2D2D2D
    Front Sensor Driver:
    Subsystem 5 - Part No SW: ----------- HW: 480 402 708 12
    Component: FrontSensor_D 001 6149
    Serial number: 3556502BF0C91105C1EL
    Coding: 2D2D2D
    Pedestrian Protection Driver:
    Subsystem 6 - Part No SW: ----------- HW: 480 401 207 12
    Component: PedP_Sensor_D 001 6149
    Serial number: 2286502A90BE4C3302FM
    Coding: 2D2D2D
    Pedestrian Protection Passenger:
    Subsystem 7 - Part No SW: ----------- HW: 480 401 207 12
    Component: PedP_Sensor_P 001 6149
    Serial number: 2296502A90BE4C30529J
    Coding: 2D2D2D
    Pedestrian Protection Center:
    Subsystem 8 - Part No SW: ----------- HW: 480 403 107 12
    Component: PedP_Sensor_C 001 6149
    Serial number: 2306502A90C37662C1FF
    Coding: 2D2D2D
    1 Fault Found:
    1050117 - Databus
    U1123 00 [008] - Received Error Message
    Intermittent - Confirmed - Tested Since Memory Clear
    Freeze Frame:
    Fault Priority: 6
    Fault Frequency: 1
    Reset counter: 217
    Mileage: 90358 km
    Date: 2020.02.20
    Time: 00:01:10
    Address 16: Steering wheel (J527) Labels:. 5Q0-953-549.clb
    Part No SW: 8V0 953 521 B HW: 5Q0 953 549 A
    Component: Lenks. Modul 007 0070
    Revision: -------- Serial number: 1410120003003A
    Coding: A408
    ASAM Dataset: EV_SMLSKLOMQB 009001
    ROD: EV_SMLSKLOMQB_009_VW37.rod
    VCID: 3972E57FB8DF7A87A2-806C
    No ASAM data for: "EV_SMLSKLOMQB" (AU37)
    Address 17: Instruments (J285) Labels:| 5G0-920-XXX-17.clb-SRI3
    Part No SW: 8V0 920 970 B HW: 8V0 920 970 B
    Component: KOMBI H23 0490
    Coding: 27AD01002B8046000100EA00000000
    ASAM Dataset: EV_DashBoardVDDMQBAB 008026
    ROD: EV_DashBoardVDDMQBAB_008_VW37.rod
    VCID: 3B7EFF77B2E34897B0-806E
    1 Fault Found:
    1048578 - No Basic Setting
    B2010 00 [009] - -
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 177
    Mileage: 90358 km
    Date: 2020.02.20
    Time: 00:15:57
    Address 19: CAN Gateway (J533) Labels:| 5Q0-907-530-V1.clb
    Part No SW: 5Q0 907 530 J HW: 5Q0 907 530 F
    Component: GW MQB High 122 1126
    Revision: -------- Serial number: 0000110780
    Coding: 030100F40B0876005B000248080B00000001000000000000000000000000
    ASAM Dataset: EV_GatewLear 008010
    ROD: EV_GatewLear_008.rod
    VCID: 3874E07B83D5638F5D-806C
    Alternator:
    Multi Function Steering Wheel Control Module:
    Subsystem 2 - Part No SW: 8U0 951 528 A HW: 8U0 951 528 A
    Component: E221 - MFL H02 0014
    Serial number: 27 09 2012 D0121202
    Battery Monitoring Control Module:
    Subsystem 3 - Part No SW: 5Q0 915 181 C HW: 5Q0 915 181 C
    Component: J367-BDMHella H03 8042
    Serial number: 9445868101
    1 Fault Found:
    15360512 - Component Protection
    Freeze Frame:
    Fault Priority: 4
    Fault Frequency: 1
    Reset counter: 180
    Mileage: 90411 km
    Date: 2020.02.21
    Time: 16:51:38
    Supply voltage: Terminal 30: 12.0 V
    Terminal 15: On
    Address 42: Door Elect, Driver (J386) Labels:| 5QX-959-X93-42.clb
    Part No SW: 5Q0 959 593 A HW: 5Q0 959 593 A
    Component: TSG FS H12 0006
    Serial number: 10091200010885
    Coding: 001C0E205C01040100001002
    ASAM Dataset: EV_DCUDriveSideEWMAXKLO 006003
    ROD: EV_DCUDriveSideEWMAXCONT.rod
    VCID: 3F868B67A6FB54B79C-806A
    Address 44: Steering Assist (J500) Labels:| 5Q0-909-144.clb
    Part No SW: 5Q0 909 144 L HW: 5Q0 909 144 K
    Component: EPS_MQB_ZFLS 119 1021
    Coding: 81
    ASAM Dataset: EV_SteerAssisMQB 008022
    ROD: EV_SteerAssisMQB_008.rod
    VCID: 3D7AF16FACF746A78E-8068
    Address 52: Door Elect, Pass.
    Cannot be reached
    Address 55: Headlight Range (J431) Labels:| 5Q0-907-357.clb
    Part No SW: 5Q0 907 357 HW: 6R0 907 357 A
    Component: LWR-ECU 005 0070
    Revision: -------- Serial number: --------------
    Coding: 019E000001000000
    ASAM Dataset: EV_HeadlRegulVWLWRMQB 001110
    ROD: EV_HeadlRegulVWLWRMQB.rod
    VCID: 75EA294FD447DEE786-8020
    Address 5F: Information Electr. (J794) Labels:* None
    Part No SW: 8V0 035 043 N HW: 8V0 035 043
    Component: MU-H-N-EU H40 0198
    Serial number: A039B0E7513513
    Coding: 01730001FF00000021110001000A00032F00010701000100DE
    Shop #: WSC 61947 001 1048576
    ASAM Dataset: EV_MUHig4CHBAS 001040
    ROD: EV_MUHig4CHBAS_AU37.rod
    Data medium:
    Subsystem 1 - Part No SW: V03 959 800 E HW: -----------
    Component: ECE 2012/13 --- 0028
    Serial number: --------------------
    Display unit 1 for multimedia system:
    Subsystem 2 - Part No SW: 8V0 919 604 A HW: 8V0 919 604 A
    Component: DU High H47 0013
    Serial number: AUZ8Z9C0700337
    Multimedia Operating Unit:
    Subsystem 3 - Part No SW: 8V0 919 614 H HW: 8V0 919 614 D
    Component: ControlUnit_H H64 0764
    Serial number: C1000023071200010153
    Compact Disc Database:
    Subsystem 4 - Part No SW: V03 959 800 EG HW: -----------
    Component: Gracenote --- 1007
    End-------------------------(Elapsed Time: 03:31)--------------------------
  2. Avatar
    snack-media
    Advertisement
  3. DJAlix
    DJAlix VAG Car Coding™ Limited Site Sponsor Gold Supporter VCDS Map User VAG Can Professional ODIS (Offboard Diagnostic System)
    6,060
    4,645
    Possible faulty door module however looking at the rest of your scan it seems you have a component protection issue with your 09 - central electric module, have you changed this?
  4. superchargedpolo
    superchargedpolo New Member
    I ran the above scan for Pete. It's an odd failure. It would appear that all these errors occured at the sametime. The car has been owned by Pete since almost new so he knows it's history well. No modules have been changed etc.
    I can't communicate with the passenger door now. You can't open it and nothing on the door works, windows etc. It's listed on the CAN gateway but you can't interrogate the module. I think all the other failures on the central electrics MAY be related to this but I'm not sure.
    The main questions would be has anyone had a similar failure of the door module or wiring harness going to it. I think this is the first place to investigate. However, how do you get at the module or harness if you can't open the door!
    Any help much appreciated.
  5. DJAlix
    6,060
    4,645
    Check power to the door module, wiring etc. For everything to happen at the same time would suggest a possible faulty 09 module tho.
  6. pedro61163
    260
    60
    Removed passenger seat today to gain access to door have managed to get door panel off. any one know how to get lock to release So I can open door
  7. pedro61163
    260
    60
    Got passenger door open
  8. pedro61163
    260
    60
    Removed glovebox and was able to remove Central convenience module. Is there a way I can test this module? Or would I be better just to buy a secondhand one.
  9. maxx16v
    maxx16v New Member VCDS Map User
    being a bit dim here.....but have you actually checked ALL fuses in ALL THE fuse boxes ??????
  10. pedro61163
    260
    60
    Yes first thing to check
  11. maxx16v
    check the loom at door jam.........they tend to break wires which causes the issues
  12. Avatar
    snack-media
    Advertisement
  13. pedro61163
    260
    60
    Door electrics now working. Also received second hand central convenience module tonight, tried in car and all exterior lights are working and light switch also stop start now working. No interior lights though. I took unit back out as getting coding done by friend this weekend.
  14. pedro61163
    260
    60
    Car booked into Aberdeen Audi tomorrow
    N.J.H likes this.
