Got a friend to do a vcds printout tonight. It won't connect with passenger door.
Thursday,27,February,2020,19:35:43:34536
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64
VCDS Version: 19.6.2.2 (x64)
Data version: 20200210 DS308.0
www.Ross-Tech.com
VIN: WAUZZZ8V3DA013274 License Plate: PETE
Mileage: 90595km-56293mi Repair Order:
Chassis Type: 8V-AU37 (5Q0)
Scan: 01 03 08 09 10 15 16 17 19 42 44 52 55 5F
VIN: WAUZZZ8V3DA013274 Mileage: 90595km-56293miles
01-Engine -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: Malfunction 0010
10-Park/Steer Assist -- Status: OK 0000
15-Airbags -- Status: Malfunction 0010
17-Instruments -- Status: Malfunction 0010
19-CAN Gateway -- Status: Malfunction 0010
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
52-Door Elect, Pass. -- Status: Malfunction 0010
55-Headlight Range -- Status: OK 0000
5F-Information Electr. -- Status: OK 0000
Address 01: Engine (J623-CRBC) Labels:. 04L-907-309-V1.clb
Part No SW: 04L 906 021 DS HW: 04L 907 309 D
Component: R4 2,0L EDC H21 4941
Revision: 83H21---
Coding: 0A190012032501082000
Shop #: WSC 34563 000 1048576
ASAM Dataset: EV_ECM20TDI01104L906021DS 002008
ROD: EV_ECM20TDI01104L906021DS_002.rod
VCID: 79F2257FF85FBA87E2-802C
No fault code found.
Readiness: 0 0 0 0 0
Address 03: ABS Brakes (J104) Labels: 5Q0-907-379-IPB-V1.clb
Part No SW: 5Q0 907 379 AC HW: 5Q0 907 379 D
Component: ESC H75 0437
Revision: 00000000 Serial number:
Coding: 10F18AA220210A6F0179060701C7290851045080608094F20279003485
ASAM Dataset: EV_Brake1UDSContiMK100IPB 008020
ROD: EV_Brake1UDSContiMK100IPB_008_VW37.rod
VCID: 7DFA316FEC7786A7CE-8028
Address 08: Auto HVAC (E87) Labels:| 8V0-820-043.clb
Part No SW: 8V0 820 043 A HW: 8V0 820 043 A
Component: AC Automat H11 0031
Revision: 20017000 Serial number: 00000000017631
Coding: 00100114002000011000000000001100
Shop #: WSC 06314 790 00021
ASAM Dataset: EV_AirCondiFrontVaAU37X 008016
ROD: EV_AirCondiFrontVaAU37X.rod
VCID: 3064D85B6BA5BBCF15-8064
Relative humidity sensor in fresh air intake duct:
Subsystem 1 - Part No SW: 4H0 907 658 HW: 4H0 907 658
Component: AQ_Hum_Sensor H03 0003
Serial number: 76784D46000000000001
Address 09: Cent. Elect. (J519) Labels:| 5Q0-937-08X-HV1.clb
Part No SW: 5Q0 937 084 Q HW: 5Q0 937 084 Q
Component: BCM MQBAB H H14 0106
Serial number: 00011227900964
Coding: 00001842C041205317A44004F10407000000000000000000000000000000
Shop #: WSC 00000 000 00000
ASAM Dataset: EV_BCMCONTI 010001
ROD: EV_BCMBOSCH_010.rod
VCID: 46889E83F921057FDF-8012
Control Unit For Wiper Motor:
Subsystem 1 - Part No SW: 8V2 955 119 A HW: 8V2 955 119 Labels: 5QX-955-119-V1.CLB
Component: WWS370 120620 041 0580
Serial number: 120808045101
Coding: 0A47F7
Sensor For Anti Theft Alarm System:
Subsystem 2 - Part No SW: 8V0 951 177 HW: 5Q0 951 172
Component: Sensor, DWA 005 0313
Serial number: 000000000ZY122352LFJ
Alarm horn:
Subsystem 3 - Part No SW: 5Q0 951 605 HW: 5Q0 951 605
Component: Sirene, DWA 004 0311
Serial number: 00000000000055148801
10 Faults Found:
9738 - Bulb for Left Parking Lamp
B12E8 15 [009] - Open or Short to Plus
Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 2
Fault Frequency: 1
Reset counter: 180
Mileage: 90411 km
Date: 2020.02.21
Time: 16:49:02
9994 - Bulb for Right Parking Lamp
B12E9 15 [009] - Open or Short to Plus
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 180
Mileage: 90411 km
Date: 2020.02.21
Time: 16:49:02
197128 - Lock Module for Central Locking; Rear Left
B12DB 29 [009] - Signal Implausible
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 180
Mileage: 90411 km
Date: 2020.02.22
Time: 12:41:24
197132 - Lock Module for Central Locking; Rear Left
B12DB 01 [009] - Electrical Failure
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 180
Mileage: 90411 km
Date: 2020.02.21
Time: 16:59:35
197384 - Lock Module for Central Locking; Rear Right
B12DC 29 [009] - Signal Implausible
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 180
Mileage: 90411 km
Date: 2020.02.22
Time: 12:41:24
197388 - Lock Module for Central Locking; Rear Right
B12DC 01 [009] - Electrical Failure
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 180
Mileage: 90411 km
Date: 2020.02.21
Time: 16:59:35
197644 - Control Circuit for Fuel Tank Flap
B1263 01 [009] - Electrical Failure
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 180
Mileage: 90411 km
Date: 2020.02.21
Time: 17:07:42
555797 - Databus
U1121 00 [009] - Missing Message
[New feature! Extended UDS fault detail is only supported by current gen. interfaces]
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 180
Mileage: 90411 km
Date: 2020.02.21
Time: 16:49:02
13697024 - Component Protection
U1100 00 [009] - No Basic Setting
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 180
Mileage: 90411 km
Date: 2020.02.21
Time: 16:49:02
15361024 - Component Protection
U1101 00 [009] - Active
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 180
Mileage: 90411 km
Date: 2020.02.21
Time: 16:49:02
Address 10: Park/Steer Assist (J791) Labels:| 5Q0-919-283.clb
Part No SW: 5Q0 919 283 A HW: 5Q0 919 283
Component: PARKHILFE 4K 009 0026
Revision: -------- Serial number: 60831225704183
Coding: 0000050001
ASAM Dataset: EV_EPHVA14AU3700000 002015
ROD: EV_EPHVA14AU3700000_002_VW37.rod
VCID: 3776E3478ECB6CF754-8062
Address 15: Airbags (J234) Labels:| 5Q0-959-655.clb
Part No SW: 5Q0 959 655 L HW: 5Q0 959 655 L
Component: AirbagVW20 009 0349
Serial number: 003GER009ZHZ
Coding: 98CCC0000C0000005C5400CA00C800000065
ASAM Dataset: EV_AirbaVW20SMEVW37X 002126
ROD: EV_AirbaVW20SMEVW37X.rod
VCID: 499295BFE83FEA0732-801C
Side Sensor Driver Front:
Subsystem 1 - Part No SW: ----------- HW: 480 000 810 12
Component: SideSensor_Df 001 0887
Serial number: 357670000002CAC4EB07
Coding: 2D2D2D
Side Sensor Passenger Front:
Subsystem 2 - Part No SW: ----------- HW: 480 000 810 12
Component: SideSensor_Pf 001 0887
Serial number: 35867000000D9939EB0B
Coding: 2D2D2D
Side Sensor Driver Rear:
Subsystem 3 - Part No SW: ----------- HW: 480 401 809 12
Component: SideSensor_Dr 001 6149
Serial number: 3516502AB0D19C31C37I
Coding: 2D2D2D
Side Sensor Passenger Rear:
Subsystem 4 - Part No SW: ----------- HW: 480 401 809 12
Component: SideSensor_Pr 001 6149
Serial number: 3526502990CD5EB1C39Z
Coding: 2D2D2D
Front Sensor Driver:
Subsystem 5 - Part No SW: ----------- HW: 480 402 708 12
Component: FrontSensor_D 001 6149
Serial number: 3556502BF0C91105C1EL
Coding: 2D2D2D
Pedestrian Protection Driver:
Subsystem 6 - Part No SW: ----------- HW: 480 401 207 12
Component: PedP_Sensor_D 001 6149
Serial number: 2286502A90BE4C3302FM
Coding: 2D2D2D
Pedestrian Protection Passenger:
Subsystem 7 - Part No SW: ----------- HW: 480 401 207 12
Component: PedP_Sensor_P 001 6149
Serial number: 2296502A90BE4C30529J
Coding: 2D2D2D
Pedestrian Protection Center:
Subsystem 8 - Part No SW: ----------- HW: 480 403 107 12
Component: PedP_Sensor_C 001 6149
Serial number: 2306502A90C37662C1FF
Coding: 2D2D2D
1 Fault Found:
1050117 - Databus
U1123 00 [008] - Received Error Message
Intermittent - Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 217
Mileage: 90358 km
Date: 2020.02.20
Time: 00:01:10
Address 16: Steering wheel (J527) Labels:. 5Q0-953-549.clb
Part No SW: 8V0 953 521 B HW: 5Q0 953 549 A
Component: Lenks. Modul 007 0070
Revision: -------- Serial number: 1410120003003A
Coding: A408
ASAM Dataset: EV_SMLSKLOMQB 009001
ROD: EV_SMLSKLOMQB_009_VW37.rod
VCID: 3972E57FB8DF7A87A2-806C
No ASAM data for: "EV_SMLSKLOMQB" (AU37)
Address 17: Instruments (J285) Labels:| 5G0-920-XXX-17.clb-SRI3
Part No SW: 8V0 920 970 B HW: 8V0 920 970 B
Component: KOMBI H23 0490
Coding: 27AD01002B8046000100EA00000000
ASAM Dataset: EV_DashBoardVDDMQBAB 008026
ROD: EV_DashBoardVDDMQBAB_008_VW37.rod
VCID: 3B7EFF77B2E34897B0-806E
1 Fault Found:
1048578 - No Basic Setting
B2010 00 [009] - -
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 177
Mileage: 90358 km
Date: 2020.02.20
Time: 00:15:57
Address 19: CAN Gateway (J533) Labels:| 5Q0-907-530-V1.clb
Part No SW: 5Q0 907 530 J HW: 5Q0 907 530 F
Component: GW MQB High 122 1126
Revision: -------- Serial number: 0000110780
Coding: 030100F40B0876005B000248080B00000001000000000000000000000000
ASAM Dataset: EV_GatewLear 008010
ROD: EV_GatewLear_008.rod
VCID: 3874E07B83D5638F5D-806C
Alternator:
Multi Function Steering Wheel Control Module:
Subsystem 2 - Part No SW: 8U0 951 528 A HW: 8U0 951 528 A
Component: E221 - MFL H02 0014
Serial number: 27 09 2012 D0121202
Battery Monitoring Control Module:
Subsystem 3 - Part No SW: 5Q0 915 181 C HW: 5Q0 915 181 C
Component: J367-BDMHella H03 8042
Serial number: 9445868101
1 Fault Found:
15360512 - Component Protection
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 180
Mileage: 90411 km
Date: 2020.02.21
Time: 16:51:38
Supply voltage: Terminal 30: 12.0 V
Terminal 15: On
Address 42: Door Elect, Driver (J386) Labels:| 5QX-959-X93-42.clb
Part No SW: 5Q0 959 593 A HW: 5Q0 959 593 A
Component: TSG FS H12 0006
Serial number: 10091200010885
Coding: 001C0E205C01040100001002
ASAM Dataset: EV_DCUDriveSideEWMAXKLO 006003
ROD: EV_DCUDriveSideEWMAXCONT.rod
VCID: 3F868B67A6FB54B79C-806A
Address 44: Steering Assist (J500) Labels:| 5Q0-909-144.clb
Part No SW: 5Q0 909 144 L HW: 5Q0 909 144 K
Component: EPS_MQB_ZFLS 119 1021
Coding: 81
ASAM Dataset: EV_SteerAssisMQB 008022
ROD: EV_SteerAssisMQB_008.rod
VCID: 3D7AF16FACF746A78E-8068
Address 52: Door Elect, Pass.
Cannot be reached
Address 55: Headlight Range (J431) Labels:| 5Q0-907-357.clb
Part No SW: 5Q0 907 357 HW: 6R0 907 357 A
Component: LWR-ECU 005 0070
Revision: -------- Serial number: --------------
Coding: 019E000001000000
ASAM Dataset: EV_HeadlRegulVWLWRMQB 001110
ROD: EV_HeadlRegulVWLWRMQB.rod
VCID: 75EA294FD447DEE786-8020
Address 5F: Information Electr. (J794) Labels:* None
Part No SW: 8V0 035 043 N HW: 8V0 035 043
Component: MU-H-N-EU H40 0198
Serial number: A039B0E7513513
Coding: 01730001FF00000021110001000A00032F00010701000100DE
Shop #: WSC 61947 001 1048576
ASAM Dataset: EV_MUHig4CHBAS 001040
ROD: EV_MUHig4CHBAS_AU37.rod
Data medium:
Subsystem 1 - Part No SW: V03 959 800 E HW: -----------
Component: ECE 2012/13 --- 0028
Serial number: --------------------
Display unit 1 for multimedia system:
Subsystem 2 - Part No SW: 8V0 919 604 A HW: 8V0 919 604 A
Component: DU High H47 0013
Serial number: AUZ8Z9C0700337
Multimedia Operating Unit:
Subsystem 3 - Part No SW: 8V0 919 614 H HW: 8V0 919 614 D
Component: ControlUnit_H H64 0764
Serial number: C1000023071200010153
Compact Disc Database:
Subsystem 4 - Part No SW: V03 959 800 EG HW: -----------
Component: Gracenote --- 1007
End-------------------------(Elapsed Time: 03:31)--------------------------
www.Ross-Tech.com
Revision: 83H21---
Coding: 0A47F7
Alarm horn:
10 Faults Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 180
Mileage: 90411 km
Date: 2020.02.21
Time: 16:49:02
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 180
Mileage: 90411 km
Date: 2020.02.21
Time: 16:49:02
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 180
Mileage: 90411 km
Date: 2020.02.22
Time: 12:41:24
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 180
Mileage: 90411 km
Date: 2020.02.21
Time: 16:59:35
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 180
Mileage: 90411 km
Date: 2020.02.22
Time: 12:41:24
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 180
Mileage: 90411 km
Date: 2020.02.21
Time: 16:59:35
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 180
Mileage: 90411 km
Date: 2020.02.21
Time: 17:07:42
555797 - Databus
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 180
Mileage: 90411 km
Date: 2020.02.21
Time: 16:49:02
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 180
Mileage: 90411 km
Date: 2020.02.21
Time: 16:49:02
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 180
Mileage: 90411 km
Date: 2020.02.21
Time: 16:49:02
Coding: 0000050001
Coding: 2D2D2D
Coding: 2D2D2D
Coding: 2D2D2D
Coding: 2D2D2D
Coding: 2D2D2D
Coding: 2D2D2D
Coding: 2D2D2D
Coding: 2D2D2D
1 Fault Found:
1050117 - Databus
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 217
Mileage: 90358 km
Date: 2020.02.20
Time: 00:01:10
Coding: A408
1 Fault Found:
B2010 00 [009] - -
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 177
Mileage: 90358 km
Date: 2020.02.20
Time: 00:15:57
Alternator:
1 Fault Found:
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 180
Mileage: 90411 km
Date: 2020.02.21
Time: 16:51:38
Terminal 15: On
Coding: 81
Cannot be reached
Data medium:
