  2. Dismiss Notice
VCDS Modifications
davidbir Sep 21, 2016
  1. Parklife
    Parklife Registered User
    134
    33
    Found the correct Bytes to change over on AudiWorld - got an error so need to retrace steps!!
  2. Avatar
    snack-media
    Advertisement
  3. mjcourtney
    mjcourtney Registered User
    1,692
    536
    Strange that you don't have any bits labelled, they're all labelled on mine.
    Sent from my Nexus 6P using Tapatalk
  4. Parklife
    134
    33
    Agree it's a bit odd, you'd think it would effect everyone. Support acknowledges it is an issue, but they say they are waiting on Audi.
  5. Parklife
    134
    33
    Went to retrace the steps today and when I started the car there were no errors, so obviously got it right yesterday!!
    mjcourtney likes this.
  6. thefunkygibbon
    thefunkygibbon Registered User
    107
    25
    so does anyone have any codings to add to this thread? just read through it and i can only see one kind soul posting about how to activate lane assist. there must be others. :)
    also, wouldn't it be a good idea to move this thread to a more generic modifications subforum rather than the A4 one given that it is relevant for many models.
  7. SLINEA4AVANT
    SLINEA4AVANT Registered User
    23
    I have just taken delivery of an A4 S Line Avant and would like to activate the maps in the DIS what is the cheapest and easiest way to do this?
    Is there anywhere in Scotland I can pay to have this done as I am not tech minded?
  8. Phil's Barber
    Phil's Barber Top Gear
    172
    54
    Obdeleven is the cheapest way to do it yourself. About 55 quid with the licence. (PRO)
    SLINEA4AVANT likes this.
  9. SLINEA4AVANT
    23
    How easy was this to do Phil?
    Phil's Barber likes this.
  10. craigomills
    craigomills Registered User
    167
    44
    So do AUDI know that any tinkering has been done when they service the vehicle and would it invalidate a warranty ? Assuming that the norm is to set to factory settings before servicing etc ??
  11. cuke2u
    cuke2u Well-Known Member
    13,031
    5,277
  12. Avatar
    snack-media
    Advertisement
  13. Parklife
    134
    33
    When mine when in to get the software updated to fix the POI issue the master tech said he had not touched the coding that had been altered. So they are aware of you change it, and depending on the tech as to whether they wipe it or not!
  14. cuke2u
    13,031
    5,277
    Maybe that's why they are asking? It's good if they accept owners will be making these sort of mods...
  15. Phil's Barber
    172
    54
    I found it pretty straight forward following the walk-through steps others have posted.
  16. Candell
    Candell Registered User
    144
    40
    Does anyone have a list of tweaks available now for each of the systems such as vagcom, odbeleven and carista? I'm thinking about getting someone up to make some tweaks if what I want is possible
  17. cuke2u
    13,031
    5,277
    Idea for a stickie, or maybe in the how to do thread?
  18. Inked
    Inked Registered User
    231
    72
    Anyone got any further updates to this? Received my OBDeleven device today and have done the high beam assist and lane assist. Thanks @mjcourtney
  19. cuke2u
    13,031
    5,277
    Inked likes this.
  20. cuke2u
    13,031
    5,277
  21. cuke2u
    13,031
    5,277
  22. Happy Grumpz
    Happy Grumpz Well-Known Member Silver Supporter
    568
    706
    93
  23. Happy Grumpz
    568
    706
    93
  24. NeilHD
    NeilHD Registered User
    106
    61
    Not cheap for what sounds like a one-use device.
  25. Happy Grumpz
    568
    706
    93
    I agree, but it's really the only thing missing on my car.
  26. shane kavanagh
    shane kavanagh Registered User
    HI looking for some help. I have a vacs and have been using it on my 2009 a4. now I have a 2017 a4 sling, and wanted to do some changes,
    But when I go to long coding helper, the boxes that are tick/unticked have no description so I dont know what Im changing why is this? any way off getting it how it was on my 2009 a4?
    Or were could I get help with some coding? Im looking to have the beep when you press the lock, and have the drl only on when its in coming home leaving home mode not the low beem. and have the leds at 100% if this is possible
  27. GavinE
    GavinE Registered User
    32
    65
    Great info. Have made both changes using this and works as expected..
    I do however appear to have lost Google Earth view since from the Nav. The selection is grayed out, although it can be selected, and appears to load it never displays the image. Have you noticed this as an issue?
    I don't tend to use it anyway, but, would like to know if this coding has affected it. I tried returning back to original coding but its the same.
  28. Happy Grumpz
    568
    706
    93
    cuke2u likes this.
  29. phope74
    phope74 Registered User
    118
    120
    43
    I take it that the process is just plug in the device to the OBD socket, let it do its thing, remove and thats it?
  30. Happy Grumpz
    568
    706
    93
    Correct, it takes less than 5 minutes from start to finish.
  31. cuke2u
    13,031
    5,277
    I have it in my car but really I can work out what speed I should be doing by using my eyes on the road ahead...
    JayK86 likes this.
  32. JayK86
    JayK86 Registered User
    24
    Hi, by any chance do you know how to enable the map display in the dashboard, using VCDS?
    For that matter, does any one else know how?
  33. Avatar
    snack-media
    Advertisement
  34. Johnny_cass
    Johnny_cass Registered User
    49
    Can anyone tell me does lane assist work with presence the one that comes with all models with no virtual cockpit. Have tried twice and just get warnings on the dash. Luckily enough I can reverse code these out. The auto dip headlights and the needle sweep work brilliantly.
    Sent from my SM-G950F using Tapatalk
  35. GavinE
    32
    65
    I have it working on mine. I do have the 7" DIS display but not virtual cockpit.
    I got errors to begin with but toggling the option off then on resolved.
    Johnny_cass likes this.
  36. Johnny_cass
    49
    Thanks for the clarification will just keep trying. Definitely got something different this time though it brought up the side sense mirror in the dash.
  37. GavinE
    32
    65
    Are you using VCDS or ODBEleven.
    If you are getting the side assist error, you may have incorrectly activated the below?
    17 - Dash Board:
    Lane Assistant>Active | Byte 4>Bit 6
    Lane Change Assistant>Active | Byte 5>Bit 3 - This should only be on if you have Audi Side Assist (blind spot monitor).
    NevMan and Johnny_cass like this.
  38. Johnny_cass
    49
    Obdeleven. I must have put on side assist thus tune using different instructions. Obdeleven is a great piece of kit
  39. Johnny_cass
    49
    I'll give it another go tomorrow thanks for the help.
  40. Johnny_cass
    49
    Tried again getting presence error and Lane assistance error on the dash. It shows on mmi but as unavailable same as presence. But when I was uncoding it I looked up and i was able to select options in lane assistance. Its a funny one. Will try again later on in the week.
  41. JayK86
    24
    Hi mate, I have also managed to enable the map on my non-vc, but like you I also have lost the google view.
    Have you managed to fix this?
  42. Johnny_cass
    49
    Tried going over again I can't get Lane assistance going. Again when uncoding I have Lane assistance options. It's a funny one.
  43. Jsmills
    Jsmills Registered User
    293
    132
    43
    I struggled with it on mine, kept getting the errors, I seem to remember the steps out there had a bit activation which relates to side assist that you don't want to enable, and enable/disable it a few times after finishing. If you post me the steps your following i'll read through and see if I can remember. Mine is the basic Mono display.
Tags:
