VCDS 18.9 Engine Adaptations
shaneod
Anyone advise on how to access full Adaptations list in engine controller on vcds 18.9? Only a few options available even after putting in access code in security. Specifically looking to adjust idle RPM. Thanks
ch1z64
C'mon you's bhoy's in Green
Silver Supporter
Sure there is a post on the Ross-tech website about how to adjust the rpm but you have to be registered with a genuine cable
shaneod
Thanks. It should be a drop down option in adaption channels in engine control module 01. For some reason there is only a few options when I select the channel drop down list. Have tried putting in the security code to access adaptations but it doesn’t work. It has me puzzled..any ideas??
