Smoking on startup...
Šubler Jul 18, 2018
  1. Šubler
    Šubler Member
    39
    12
    Hi,
    i have and S3 with smoking problem...
    On startup there is a big blow of smoke coming out of exhaust, its the blue smoke (oil), its there only for a second or two, then the car runs normal, no sign of any smoke while driving hard or slow.
    Oil level is not droping, turbo has 5k km on it, genuine BorgWarner...
    Im thinking about changing valve seals as first.
    Thanks for your advices guys!
  2. Avatar
    Google AdSense Advertisement
  3. mrsingh2u
    mrsingh2u Member
    75
    32
    Check all the usual stuff like oil drain routing from the turbo, the presence of a flow restrictor in your oil feed line etc first before tearing the head off to examine valve stem seals...
    Sent from my H3213 using Tapatalk
  4. Šubler
    Šubler Member
    39
    12
    Thanks for advice, does oil feed has something to do with this? or just oil drain route? will take a look!
  5. Šubler
    Šubler Member
    39
    12
    no more ideas?
  6. tcg
    tcg Well-Known Member
    780
    353
    I'm guessing you've replaced the turbo recently,if so,has the problem occurred since then?
    If it has,it may be from oil left in the intercoolers,if they wren't cleaned out when the turbo was changed.
    Apologies,in advance,if you've already cleaned them :blush:
  7. JonnyDerv
    JonnyDerv Active Member
    692
    136
    43
    If it’s only on start up, and everything was cleaned and fitted correctly with the new turbo, then I’d suspect valve stem seals.
  8. Šubler
    Šubler Member
    39
    12
    Turbo was replaced half a year ago, since then i had fited an FMIC, brand new one.
  9. Šubler
    Šubler Member
    39
    12
    I thought, if steam seals are shot the car would smoke all the time, or not?
  10. JonnyDerv
    692
    136
    43
    Nope with valve stem seals you usually see a blue puff of smoke on cold start up or if you’re sitting at lights etc. Reason being oil is pumped up into the head during running, and when it’s turned off for a long period, say overnight, the seal cools and contracts, keeping the oil sitting there, then opens up when you start it up, dropping the oil into the cylinders. When sitting idling the engine vaccum causes oil to congregate around the seals, and then drop in when you move again.
    If there’s blue smoke pouring out whilst accelerating then it’s going to be turbo or piston rings. If you’re completely certain the turbo was fitted correctly and you’re smoking under load then I’d want to do a leak down and compression test to check your rings.
  11. Stuart B
    Stuart B Well-Known Member
    3,448
    739
    I watched an video recently explaining most turbo / oil issues are because the feed line back to the sump is ineffective or too much blow by gases dont allow the feed to return to the sump then the oil lubrication / cooling overfills as it's being pumped in with nowhere to go. that's probably not your problem but hey :D
  12. Avatar
  13. Šubler
    Šubler Member
    39
    12
    Under load there is absolutely no smoke!
    So i hope its the steam seals then, thnk for advices will report back when i change them :)
