  2. Dismiss Notice
SD Card Data Corrupted issue
J3oef Jul 13, 2018
  1. J3oef
    J3oef Registered User
    35
    25
    Hi all,
    First time posting and hopefully it's an easy solution.
    My wife has an Audi TT S Line Black Edition MK2 with the audi navigation plus unit.
    I've purchased a 64GB SanDisk Ultra SDXC card in the hope of putting music on it and using in the unit.
    However I'm getting data corrupted when inserting card. I've tried to reformat various times to fat32 but still having no joy.
    The card works fine in the laptop and will play the music direct from card when plugged in.
    Hopefully someone can advise how I can get this working. I have a feeling the card is too big although I'm sure I read various posts on other forums about 64gb cards being fine.
  2. Avatar
    snack-media
    Advertisement
  3. allanmb
    allanmb Registered User
    802
    561
    93
    Try formatting it as ExFAT. That is usually more compatible.
  4. ch1z64
    ch1z64 C'mon you's bhoy's in Green Silver Supporter VCDS Map User
    4,090
    876
    Have you tried a lower GB card , i use a 32gb and works fine with mp3 files so it could be card to large
  5. allanmb
    802
    561
    93
    It *should* be ok with the size of card. I'm using a 128GB USB drive with no problems
  6. ch1z64
    4,090
    876
    Just found in other forum posts that the Rns-e mk2 2010 will only take 2x32gb sdhc cards . If you can give your model number which is on a label on the top or somewhere on it as that will help cheers.
    ( https://www.ttforum.co.uk/forum/viewtopic.php?f=19&t=229979 )
  7. allanmb
    802
    561
    93
    Oh sorry, you're right @ch1z64 , RNSe is old and will only take up to 32GB SDHC - in fact the first gen only took 2GB cards max IIRC
  8. ch1z64
    4,090
    876
    Even us not so known members can be right :welcoming::welcoming::welcoming::cheerful:
    allanmb likes this.
  9. Oli Relf
    Oli Relf Registered User
    I had this issue. Had to use a windows machine rather than a Mac.
  10. RCD6FC
    RCD6FC Registered User
    100
    96
    I'm a bit late to the party, but I can confirm what ch1z64 and allanmb have said. I had a look in my RNS-E nav system operating manual (smaller booklet, separate to the TT owner's manual) and there is a table showing the maximum capacity of the cards supported is 32 Gb and it also states that it wants FAT or FAT32 format.
    I had a different issue when I first went to listen to audio files on a memory card in that my files were not MP3s. They were a different audio format (I believe it was WAV) and the system couldn't read them and told me that I had a very nice blank card. Once I converted the files to MP3, there were no issues using the card with the system.
  11. ch1z64
    4,090
    876
    Remember lads even thou it is a lot off memory ( was in its day ) that the system will only show X amount off Folders and Files so be careful you dont overload with Mp3 as it will only read so many and you will think where has all my other media ( mp3's ) went .:thumbs up:
  12. Avatar
    snack-media
    Advertisement
  13. RCD6FC
    100
    96
    ch1z64 - true!
    That handy little table in the operating manual also shows you you will be limited to:
    - Maximum 15,000 files per medium.
    - Maximum 5,o00 directories.
    - Maximum 2,000 files per directory.
  14. RCD6FC
    100
    96
    Not sure why I had to say"you" twice, but never mind. You're also limited to a maximum of 32 playlists.
