S4 brakes on a4 b6
I've done it and it's easy .. Fronts just bolt on but the rears you need to trim the dust shield down a little to make it fit also the hand break cables are a little tighter to put back on but not that hard
Reactions: SL11CKK
what about the rotors offset on a4/s4, are they the same offset?
i've read they have different offset and might be hard to just bolt it right on on standard a4?
and how do you rate the increased stopping power?
Same off set they just bolt straight on the only thing you need to mod is the rear s4 dust guard and the hand break cable .. Like i already said .. And the stopping power is miles better then standard
Great.. Tried to find the offset of the rotors but didn't find it..
I've seen how to get the dust shield and brake lines to go without a problem..
How easy is it to do it myself.? I like to think of myself very handy with tools and mechanically minded.
The fronts are just a swop over Very easy to do but the rear are a bit tricky but nothing to hard .. the hardest thing is bleeding your breaks after .. There's a how to on Audi zone I think
Reactions: SemedoB6
647
czm
35
888
