- Joined
- Dec 28, 2008
- Messages
- 3,247
- Reaction score
- 903
- Points
- 113
- Location
- Reading - Berkshire
- Website
- www.maidenhead-systema.co.uk
It can overheat and go into protection mode, you normally lose gears 1,3,5 or 2,4,6 if you get that message. If it shows a crossed through R you lose reverse as well.
If you read the manual it says you won't be able to restart the car if you get that error, but I was able to as I got those errors pretty much everyday and lost gears. Turned off and on and was ok, but then gears were clunky.
My clutches burnt out were the cause, which warranties won't cover. Best bet is get a warranty and if it occurs try to get the box replaced as otherwise it's a £2.4k+ bill to change the clutches.
Either that or your mechs on its way out and will cost you £3.5k...
Get it scanned on carista or vcds to show the error
