New VCDS user
Eren S3
Pretending to know what I'm doing.
Silver Supporter
Hey all,
Just purchased a VCDS cable from Gendan, should be arriving tomorrow. I feel like I'm in a safe place here to ask questions when I inevitably come to a code that I need deciphering. :innocent:
Got the cable mainly for diagnostics since I've had the engine light pop up twice (first one was plugged in and cleared due to an EVAP fault code - didn't get a chance to get the code before it was cleared but I think it's down to the PCV which will be changed tomorrow). The engine light popped up again yesterday which I am hoping to diagnose tomorrow - hoping it is the same fault. No other fault codes came up during the last full auto-scan which was only about 2 weeks ago so I'm quietly hopeful it's the same problem. I'll update tomorrow with the results from the scan. I've had the squeaking, little birdie noise from under the bonnet too these last 2 days which I believe is linked to the faulty PCV.
May eventually learn how to code in the necessary features if or when they are required too. I love a challenge so let's dive into the world of VCDS :flushed:
Cheers for now,
Eren
processpaul
Congratulations on your wise choice of a genuine lead. Plenty of knowlegable members here Eren. Get that autoscan posted up (delete chassis number for security reasons)
Don't forget to register your lead with Ross-tech for further support.
And best of all your wallet won't get robbed by the dealer..
Eren S3
Silver Supporter
Nice one Eren. I’m sure you will master it very quickly. when your ready I can add you to the vcds map :)
Thanks Sandra :) That sounds great, I'll get learning!
Thanks for your comments Paul. Yes, genuine was the only choice for me, I wouldn't trust anything other than genuine going into my car or computer! First scan is on the way :)
Eren S3
Silver Supporter
First auto-scan below. LEDs causing issues which I know about, resistors for the DRLs are due today and some new bulbs from Trups for the sidelights coming soon :)
The engine ones are the ones getting me. The intake air leak - it's got a ramair filter on it from the previous owner but I'm not sure it was ever mapped so the car may be confused. It's also got a Milltek race cat on it which is potentially causing that emissions issue.
Edit: checking the error codes on Ross-Tech shows a possible PCV failure as a reason for the code which is half what I suspected. I have a forge PCV delete plate inbound - annoyingly it's delayed until tomorrow so I can't fit it until then. Oil catch can will be fitted soon to complete the setup.
What's the usual procedure with this - fit the new part, clear codes and then re-scan?
Thanks!
Tuesday,11,December,2018,11:32:14:57859
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64
VCDS Version: 18.9.0.4 (x64) HEX-V2 CB: 0.4436.4
Data version: 20181017 DS296.0
www.Ross-Tech.com
VIN: License Plate: FIRST SCAN
Mileage: 207200km-128748mi Repair Order:
Chassis Type: 8P (1K0)
Scan: 01 03 08 09 15 16 17 19 22 25 37 42 44 46 52 55 56 77
VIN: Mileage: 207200km-128748miles
01-Engine -- Status: Malfunction 0010
03-ABS Brakes -- Status: OK 0000
04-Steering Angle -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: Malfunction 0010
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: Malfunction 0010
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: Malfunction 0010
22-AWD -- Status: OK 0000
25-Immobilizer -- Status: OK 0000
37-Navigation -- Status: Sporadic communication error 1000
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
46-Central Conv. -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
55-Headlight Range -- Status: OK 0000
56-Radio -- Status: Sporadic communication error 1000
77-Telephone -- Status: OK 0000
Address 01: Engine Labels:. 06F-907-115-AXX.clb
Part No SW: 8P0 907 115 H HW: 8P0 907 115 B
Component: 2.0l R4/4V TFSI 0050
Revision: 5BH16--- Serial number: AUX7Z0G9FNP0D7
Coding: 01030003180F0060
Shop #: WSC 66565 257 00032
VCID: 372B283B9343A48F6F1-8062
2 Faults Found:
008825 - Leak in Air Intake System
P2279 - 002 -
Freeze Frame:
Fault Status: 01100010
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 206712 km
Time Indication: 0
Date: 2018.11.28
Time: 17:12:48
Freeze Frame:
RPM: 849 /min
Load: 16.1 %
Speed: 0.0 km/h
Temperature: 67.0°C
Temperature: 36.0°C
Absolute Pres.: 1000.0 mbar
Voltage: 13.843 V
001056 - Catalyst System; Bank 1
P0420 - 002 - Efficiency Below Threshold - Intermittent - MIL ON
Freeze Frame:
Fault Status: 10100010
Fault Priority: 0
Fault Frequency: 4
Reset counter: 255
Mileage: 206731 km
Time Indication: 0
Date: 2018.11.28
Time: 18:00:36
Freeze Frame:
RPM: 1878 /min
Load: 27.4 %
Speed: 49.0 km/h
Temperature: 72.0°C
Temperature: 32.0°C
Voltage: 13.970 V
Readiness: 0000 0000
Address 03: ABS Brakes Labels: 1K0-907-379-MK60-A.lbl
Part No SW: 1K0 907 379 AB HW: 1K0 907 379 AB
Component: ESP 4MOTION MK60 0102
Revision: 00H13001
Coding: 0021128
Shop #: WSC 06314 000 00000
VCID: 72BDD92FB8A101A798F-8026
No fault code found.
Address 08: Auto HVAC Labels: 8P0-820-043.lbl
Part No SW: 8P0 820 043 AH HW: 8P0 820 043 AH
Component: KlimavollautomatH19 0420
Revision: 113804 Serial number: 8P0820043AH
Shop #: WSC 00000 000 00000
Address 09: Cent. Elect. Labels:. 8P0-907-279-30-H.lbl
Part No SW: 8P0 907 279 K HW: 8P0 907 279 K
Component: Bordnetz-SG H54 2501
Revision: 00H54000 Serial number: 00000007852973
Coding: F18E1F07A01410004F0000000000000000084E175A050000000000000000
Shop #: WSC 06314 000 08192
VCID: 45D752F3D9AFC61FEDD-8010
Subsystem 1 - Part No: 8P2 955 119 E Labels: 1KX-955-119.CLB
Component: Wischer AU350 H01 0130
Coding: 00062736
Shop #: WSC 06314
Subsystem 2 - Part No: 4E0 910 557 B Labels: 8K0-955-559.CLB
Component: REGENLICHTSENSORH13 0100
Coding: 00141886
Shop #: WSC 06314
5 Faults Found:
02394 - Parking Light Left Front (M1)
012 - Electrical Fault in Circuit - Intermittent
Freeze Frame:
Fault Status: 00101100
Fault Priority: 2
Fault Frequency: 4
Reset counter: 141
Mileage: 206728 km
Time Indication: 0
Date: 2018.11.28
Time: 17:43:00
Freeze Frame:
ON
Voltage: 13.95 V
ON
ON
OFF
OFF
OFF
02395 - Parking Light Front Right (M3)
Freeze Frame:
Fault Status: 01101100
Fault Priority: 2
Fault Frequency: 1
Reset counter: 104
Mileage: 206655 km
Time Indication: 0
Date: 2018.11.28
Time: 14:06:00
Freeze Frame:
ON
Voltage: 11.95 V
ON
ON
OFF
OFF
OFF
02745 - Bulb for Daytime Running Light; Left
010 - Open or Short to Plus
Freeze Frame:
Fault Status: 01111010
Fault Priority: 2
Fault Frequency: 4
Reset counter: 104
Mileage: 206655 km
Time Indication: 0
Date: 2018.11.28
Time: 14:04:00
Freeze Frame:
ON
Voltage: 12.00 V
ON
ON
OFF
OFF
OFF
007 - Short to Ground - Intermittent
Freeze Frame:
Fault Status: 00110111
Fault Priority: 2
Fault Frequency: 1
Reset counter: 136
Mileage: 206833 km
Time Indication: 0
Date: 2018.12.04
Time: 13:57:00
Freeze Frame:
ON
Voltage: 12.00 V
ON
ON
OFF
OFF
OFF
02746 - Bulb for Daytime Running Light; Right
Freeze Frame:
Fault Priority: 2
Fault Frequency: 3
Reset counter: 104
Mileage: 206655 km
Time Indication: 0
Date: 2018.11.28
Time: 14:04:00
Freeze Frame:
ON
Voltage: 12.00 V
ON
ON
OFF
OFF
OFF
Address 15: Airbags Labels: 8P0-959-655-94.lbl
Part No SW: 8P0 959 655 N HW: 8P0 959 655 N
Component: Airbag 9.41 H01 4230
Revision: 91H01423 Serial number: 003CR000P25V
Coding: 0071612
VCID: 4DC76AD301DF3E5F25D-8018
Subsystem 1 - Serial number: 63328RB4032B48BBS
Subsystem 2 - Serial number: 63428RB4032971034
Subsystem 3 - Serial number: 63528RB4032B4822C
Subsystem 4 - Serial number: 63628RB4032971058
Subsystem 5 - Serial number: 63747RB402E2EB15W
Subsystem 6 - Serial number: 63847RB402E2EA97%
Address 16: Steering wheel Labels: 8P0-953-549-F.lbl
Part No SW: 8P0 953 549 F HW: 8P0 953 549 F
Component: J0527 H36 0070
Coding: 0004012
VCID: 41DF46E3CD87EA3FD15-8014
Subsystem 1 - Part No: XXXXXXXXXXX
Component: E0221 H02 0030
1 Fault Found:
01304 - Radio
004 - No Signal/Communication - Intermittent
Address 17: Instruments Labels: 8P0-920-xxx-17-MY8.clb
Part No SW: 8P0 920 981 L HW: 8P0 920 981 L
Component: KOMBIINSTR. VDO H20 0640
Revision: D0H20001 Serial number: 2249G001100066
Coding: 0005428
Shop #: WSC 34281 067 57207
Address 19: CAN Gateway Labels:. 1K0-907-530-V3.clb
Part No SW: 1K0 907 530 L HW: 1K0 907 951
Component: J533__Gateway H15 0180
Revision: H15 Serial number: 1400K078070429
Coding: E9831F064006020101
VCID: 30391327762D73B72EB-8064
2 Faults Found:
01304 - Radio
Freeze Frame:
Fault Status: 00100100
Fault Priority: 2
Fault Frequency: 1
Reset counter: 143
Mileage: 207177 km
Time Indication: 0
Date: 2018.12.10
Time: 10:43:59
01300 - Control Module for Navigation with CD-Rom (J401)
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 143
Mileage: 207177 km
Time Indication: 0
Date: 2018.12.10
Time: 10:43:59
Address 22: AWD Labels: 1K0-907-554.lbl
Part No: 1K0 907 554 L
Component: Haldex 4Motion 0116
Coding: 0000001
VCID: 3635253F94495D87747-8062
Address 25: Immobilizer Labels: 1K0-920-xxx-25.clb
Revision: D0H20001 Serial number: AUX7Z0G9FNP0D7
Address 37: Navigation Labels: 8E0-035-192-RNSE.clb
Part No SW: 8P0 035 192 Q HW: 8P0 035 192 Q
Component: RNS-E HIGH EU H74 0650
Revision: 05S Serial number: AUZBZ7G0917024
Coding: 0209717
Shop #: WSC 00236 210 184094
VCID: 3D273A13B17F8EDFB5D-8068
Address 42: Door Elect, Driver Labels: 8P0-959-801-MIN3.lbl
Part No SW: 8P0 959 801 K HW: 8P0 959 801 K
Component: Tuer-SG H03 0050
Coding: 0000560
VCID: 43D34CEBD79BF82FC39-8016
Address 44: Steering Assist Labels: 1Kx-909-144-G2V3.clb
Part No: 1K2 909 144 M
Component: EPS_ZFLS Kl.150 H08 1901
Shop #: WSC 02069 000 90108
Address 46: Central Conv. Labels: 8P0-959-433.lbl
Part No: 8P0 959 433 J
Component: KSG H11 0080
Coding: 1980202002186D298505489AC637
Subsystem 1 - Part No: 1K0 951 605 C
Component: LIN BACKUP HORN H03 1301
Subsystem 2 - Part No: 1K0 907 719 C
Component: Neigungssensor 005 0003
Subsystem 3 - Part No: 8P0 951 177
Component: Innenraumueberw.H04 0020
Address 52: Door Elect, Pass. Labels:. 1K0-959-702-MIN3.clb
Part No SW: 8P0 959 802 K HW: 8P0 959 802 K
Coding: 0000560
VCID: 44D14FF7D295FF17FA3-8010
Address 55: Headlight Range Labels: 8P0-907-357.lbl
Part No: 8P0 907 357 H
Component: Dynamische LWR H01 0010
Revision: 00000001 Serial number:
Coding: 0000012
VCID: 3FDB401BBB739CCFA71-806A
Address 56: Radio Labels: 8E0-035-192-RNSE.clb
Coding: 0209717
Address 77: Telephone Labels: 8P0-862-335.lbl
Part No SW: 8P0 862 335 Q HW: 8P0 862 335 Q
Component: FSE_255x BT H26 0350
Revision: 00000000 Serial number: 00000005274408
Coding: 0011422
End----(Elapsed Time: 01:15, VBatt start/end: 11.9V/11.9V. VIgn 11.9V)-----
Address 09: DTCs cleared
09-Cent. Elect. -- Status: OK 0000
2 Faults Found:
P2279 - 002 -
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 206712 km
Time Indication: 0
Date: 2018.11.28
Time: 17:12:48
Freeze Frame:
RPM: 849 /min
Load: 16.1 %
Speed: 0.0 km/h
Temperature: 67.0°C
Temperature: 36.0°C
Voltage: 13.843 V
Freeze Frame:
Fault Priority: 0
Fault Frequency: 4
Reset counter: 255
Mileage: 206731 km
Time Indication: 0
Date: 2018.11.28
Time: 18:00:36
Freeze Frame:
RPM: 1878 /min
Load: 27.4 %
Speed: 49.0 km/h
Temperature: 72.0°C
Temperature: 32.0°C
Voltage: 13.970 V
Revision: 00H13001
Coding: 0021128
Coding: 00062736
Shop #: WSC 06314
Coding: 00141886
Shop #: WSC 06314
Coding: 0071612
Coding: 0004012
1 Fault Found:
01304 - Radio
Coding: 0005428
2 Faults Found:
01304 - Radio
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 143
Mileage: 207177 km
Time Indication: 0
Date: 2018.12.10
Time: 10:43:59
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 143
Mileage: 207177 km
Time Indication: 0
Date: 2018.12.10
Time: 10:43:59
Coding: 0000001
Coding: 0209717
Coding: 0000560
Coding: 0000560
Coding: 0000012
Coding: 0209717
Coding: 0011422
End----(Elapsed Time: 01:11, VBatt start/end: 11.9V/11.9V. VIgn 11.9V)-----
Eren S3
Silver Supporter
OK, update since the scan. Changed the PCV to the Forge delete plate, cleared the faults and the MIL light went off. Still showed up an error as follows.
2 Faults Found:
P2279 - 002 -
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 206712 km
Time Indication: 0
Date: 2018.11.28
Time: 17:12:48
Freeze Frame:
RPM: 849 /min
Load: 16.1 %
Speed: 0.0 km/h
Temperature: 67.0°C
Temperature: 36.0°C
Voltage: 13.843 V
Freeze Frame:
Fault Status: 00100010
Fault Priority: 0
Fault Frequency: 4
Reset counter: 255
Mileage: 206731 km
Time Indication: 0
Date: 2018.11.28
Time: 18:00:36
Freeze Frame:
RPM: 1878 /min
Load: 27.4 %
Speed: 49.0 km/h
Temperature: 72.0°C
Temperature: 32.0°C
Voltage: 13.970 V
Checked all the connections, no obvious leaks. Cleaned the MAF sensor and re-scanned and it seemed to clear all the errors. Potentially need a new MAF sensor? What's odd is I have a very strange knocking noise around the cone filter of the intake. I'll add a link to the noise below, trying to figure this out now. I'm about to purchase a new brake booster hose unit as well since I have had a crack in that for the last week I've seen. I've changed the damaged line since as a temporary fix but to be safe I have seen this one online.
https://www.buycarparts.co.uk/vaico/8007545
Thanks all.
