That is one really neat,clean,tidy engine bay.
Cheers Alex, it's untouched other than fitting the cai. I've driven it for nearly 10,000 without a clean. my mk2 golf bay wouldn't look this clean after that many miles ha
Gents
Received revo induction kit today, is it necessary to disconnect the battery? Or is this purely for safety measures
Didn't disconnect mine when it was fitted (Revo CAI), and no issues here.
To the OP, lovely car and some great mods. Engine bay looks a treat. Keep it coming!
Anyone any comments on the need for a Revo PCV Re-vamp kit for an S3 2011 Stage 1 going to Stage 2+?
Revo PCV Re-vamp Kit 2 0 TFSI
I was going to ask the same question. My original PCV had to be changed a year after going to Stage 1, luckily it was done under warranty. I wasn't aware of the problem of PCVs failing on tuned engines back then so it's interesting that Revo released this.
Need to identify an updated intercooler, any comments on these seem reasonable???
AIRTEC Stage 2 Audi S3 2.0 TFSi Uprated Intercooler- HUGE 55mm CORE! | eBay
130 cheaper than a forge unit
Bit of a novice question: what's the benefit of these then? I presume a more stable ride or do they drop the car slightly
Excellent thread, just read it from the beginning there. Cracker s3 mate, and some lovely mods so far. Im running the REVO Ceramic CAI if you have any questions on it. I am also really interested in your opinions on the B8's as I was seriously considering these before going with my KW coilovers. Lastly I dont have a great opinion on the REVO PCV revamp. It warped the plastic face of the rocker cover that its attached to, and I am certain the car didnt run as smoothly with it on. Im back to standard now.
Pity the problem you had with the PCV valve on yours.
I have the Forge kit on mine currently and I think the issue with the plastic cam cover is down to metal parts being bolted into plastic which isn't always a good mix.
My next kit is doing away with recirculating breathers entirely.
And a new cam cover.
Checked out the forge kit and it still looks like a metal plate fitted to the plastic cover, is there a difference I'm missing?
will see how you fair as needing some dampers soon, bringing out the OCD i would have steamed cleaned them arch liners lol
You're not missing anything.
I think the issue is going to be how tight it's torqued down and what the alloy vs plastic expansion rates are in determining if it warps the cover a bit.
Mine hasn't given any problems.
any advice on torque settings?
Yeah ive said that a few times on here in different threads. I rate the Revo kit highly but I do not think its "ready to rock" straight out of the box. See below.Cheers trev, glad you like it. I've seen some threads with an additional bracket fitted to the rear right of the engine holding the REVO intake, do you think it needs additional support?
Unlucky with the PCV, seeing as its plastic could it be something to do with how tight the screws/bolts were?
You can probably notice the extra bracket at the top there. Trimmed the head shield a bit as well to avoid rubbing. I also made another custom bracket that attaches from the bottom of the heat shield to a mounting on the front of the car. The end result is a rock sturdy system.
And I followed the instructions to a T with the PCV revamp. Possibly something to do with what Alex was saying about metal to plastic. I have seen other revamp kits though with the same design. I also know of people running them without issue. So I really dont know.
Oh yeah that bit is the same. See the wee cutout beneath the silver jubilee clips? I made that a wee bit longer, as the clips were actually rubbing against the heat shield, wheras now they are not. (Bit they were rubbing on is now cut away).
Yeah mate spot on.
Looks good mate - how much were all the trims ?
Probably cheaper to go to a professional trimmer and let him do all the fiddly work
Don't ask they are not cheap an the missus might see this, but they are top quality. Got them off darling-buds on ebay. Doesn't seem to have any listed at the moment but if you search "audi exclusive leather" completed listings you can see how much they went for.
Common problem I'm seeing with cars these days .... the missus
