So my lead turned up...
First time ive used VCDS ... managed to get hooked up... quite straight forward and my first scan running....
A Few faults flagged up and as i suspected the
19557 - Motor for Intake Manifold Flap (V157)
P3101 - 000 - Open or Short to Ground
Looks like ill be swapping out the throttle body after all :-(
This next fault was a bit of a surprise :-s
17055 - Cylinder 1 Glow Plug Circuit (Q10)
P0671 - 000 - Electrical Fault
Wednesday,21,October,2015,12:35:50:33490
VCDS -- Windows Based VAG/VAS Emulator
VCDS Version: 12.12.3.0 (x64)
Data version: 20140905
VIN:
Mileage: 89241mi Repair Order:
Chassis Type: 8P (1K0)
Scan: 01 03 08 09 15 16 17 19 25 42 44 46 47 52 56 76 7D
Mileage: /89241miles
00-Steering Angle Sensor -- Status: OK 0000
01-Engine -- Status: Malfunction 0010
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: Malfunction 0010
15-Airbags -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
25-Immobilizer -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
46-Central Conv. -- Status: Malfunction 0010
47-Sound System -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
56-Radio -- Status: Malfunction 0010
76-Park Assist -- Status: Malfunction 0010
7D-Aux. Heat -- Status: OK 0000
Address 01: Engine Labels: 03G-906-016-BKD.lbl
Part No SW: 03G 906 016 FF HW: 028 101 190 5
Component: R4 2,0L EDC 0000SG 7364
Revision: 12345678 Serial number:
Coding: 0000072
Shop #: WSC 06314 000 00000
VCID: 6CD1B2EB4F09257E575-8039
5 Faults Found:
17054 - Glow Plug Module 1; Glow Plug Circuit
P0670 - 000 - Electrical Malfunction
Freeze Frame:
RPM: 840 /min
Torque: 38.0 Nm
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 14.29 V
Bin. Bits: 11000111
Temperature: 12.6°C
Bin. Bits: 10110000
Freeze Frame:
RPM: 903 /min
Torque: 72.0 Nm
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 14.29 V
Bin. Bits: 11000100
Temperature: 0.0°C
Bin. Bits: 10110000
Freeze Frame:
RPM: 1176 /min
Torque: 44.0 Nm
Speed: 31.0 km/h
Load: 13.7 %
Voltage: 14.44 V
Bin. Bits: 11000100
Torque: 170.0 Nm
Torque: 72.0 Nm
17075 - Fan 1 Control Circuit
P0691 - 000 - Short to GND
Freeze Frame:
RPM: 1638 /min
Torque: 80.0 Nm
Speed: 41.0 km/h
Load: 21.6 %
Voltage: 14.36 V
Bin. Bits: 11000000
Temperature: 68.4°C
Duty Cycle: 9.6 %
19558 - Motor for Intake Manifold Flap (V157)
P3102 - 000 - No Signal
Freeze Frame:
RPM: 0 /min
Torque: 0.0 Nm
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 12.16 V
Bin. Bits: 00000100
Torque: 0.0 Nm
Torque: 354.0 Nm
Readiness: 1 2 0 0 0
Address 03: ABS Brakes Labels: 1K0-907-379-MK60-F.lbl
Part No SW: 1K0 907 379 Q HW: 1K0 907 379 Q
Component: ESP FRONT MK60 0102
Revision: 00T12001
Coding: 0023170
VCID: 4089365B1301111EDBD-8015
No fault code found.
Address 08: Auto HVAC Labels: 8P0-820-043.lbl
Part No SW: 8P0 820 043 H HW: 8P0 820 043 H
Component: KlimavollautomatH15 0200
Revision: 198219 Serial number: 8P0820043H
VCID: 316F639FA8AB8896243-8064
Address 09: Cent. Elect. Labels: 8P0-907-279-23-H.lbl
Part No SW: 8P0 907 279 F HW: 8P0 907 279 F
Component: Bordnetz-SG H36 1201
Revision: 00H36000 Serial number: 00000001974559
Coding: 05884F06A214100000000000000000000008FE175C0100
Shop #: WSC 06314 000 08192
Subsystem 1 - Part No: 8P2 955 119 B Labels: 1KX-955-119.CLB
Component: Wischer AU350 H01 0130
Coding: 00062736
Shop #: WSC 06314
2 Faults Found:
00906 - Horn (H1)
009 - Open or Short to Ground - Intermittent
Freeze Frame:
Fault Status: 00101001
Fault Priority: 2
Fault Frequency: 1
Reset counter: 223
Mileage: 143505 km
Time Indication: 0
Date: 2015.10.17
Time: 16:41:00
Freeze Frame:
OFF
Voltage: 12.40 V
OFF
ON
OFF
OFF
OFF
00926 - Terminal 30
011 - Open Circuit - Intermittent
Freeze Frame:
Fault Status: 00101011
Fault Priority: 4
Fault Frequency: 1
Reset counter: 223
Mileage: 143505 km
Time Indication: 0
Date: 2015.10.17
Time: 16:41:00
Freeze Frame:
OFF
Voltage: 5.00 V
OFF
ON
OFF
OFF
OFF
Address 15: Airbags Labels: 8P0-959-655-94.lbl
Part No SW: 8P0 959 655 H HW: 8P0 959 655 H
Component: Airbag 9.41 H11 3520
Revision: 91H1135 Serial number: 0037W0004JZE
Coding: 0071612
VCID: 479B2D47362F26261A7-8012
Subsystem 1 - Serial number: 63328RB40070C478G
Subsystem 2 - Serial number: 63428RB4006EA606L
Subsystem 3 - Serial number: 63528RB40070C4519
Subsystem 4 - Serial number: 63628RB4006EA685U
Subsystem 5 - Serial number: 63729RB4007AFD5E4
Subsystem 6 - Serial number: 63829RB4007AFCC1+
Address 16: Steering wheel Labels: 8P0-953-549.lbl
Part No SW: 8P0 953 549 E HW: 8P0 953 549 E
Component: Lenksäulenmodul H34 0070
Coding: 0002012
Subsystem 1 - Part No: XXXXXXXXXXX
Component: Lenkradmodul H07 0080
Address 17: Instruments Labels: 8P0-920-xxx-17-MY7.lbl
Part No SW: 8P0 920 981 B HW: 8P0 920 981 B
Component: KOMBIINSTR. VDO H80 0400
Revision: D02 Serial number: 2245ED02000557
Coding: 0004413
Shop #: WSC 28022 576 90954
VCID: 377B5D8746CF56A66A7-8062
Address 19: CAN Gateway Labels: 1K0-907-530-V1.clb
Part No SW: 1K0 907 530 D HW: 1K0 907 951
Component: Gateway H08 0100
Revision: 08 Serial number: 25001055268900
Coding: 3D0F0F42070101
VCID: 28598EFB9B71C95EF3D-807D
Address 25: Immobilizer Labels: 1K0-920-xxx-25.clb
Revision: D02 Serial number: AUX7Z0E5FN202D
Shop #: WSC 00000 000 00000
Address 42: Door Elect, Driver Labels: 8P0-959-801-MIN2.lbl
Part No: 8P0 959 801 H
Component: Tuer-SG 020 0050
Coding: 0000632
Address 44: Steering Assist Labels: 1Kx-909-14x-44.clb
Part No: 1K2 909 144 J
Component: EPS_ZFLS Kl.5 D04 1606
VCID: 3363699752B7BA8656F-8066
Address 46: Central Conv. Labels: 8P0-959-433.lbl
Part No: 8P0 959 433
Component: KSG H03 0040
Coding: 198000186D288505489AC63300
VCID: F9FF1BBFB05B00D65C3-80AC
Subsystem 1 - Part No: 1K0 951 605 C
Component: LIN BACKUP HORN H03 1301
Subsystem 2 - Part No: 1K0 907 719 C
Component: Neigungssensor 005 0003
Subsystem 3 - Part No: 8P0 951 177
Component: Innenraumueberw.H03 0020
2 Faults Found:
00926 - Terminal 30
00956 - Key 2
005 - No or Incorrect Basic Setting / Adaptation - Intermittent
Address 47: Sound System Labels: 8Px-035-382.lbl
Part No SW: 8P3 035 382 HW: 8P3 035 382
Component: AB2 SUBWOOFERBOXH25 0160
Revision: 00003 Serial number: 10000001258203
VCID: F0E9269BE321419EEBD-80A5
Address 52: Door Elect, Pass. Labels: 8P0-959-802-MIN2.lbl
Part No: 8P0 959 802 H
Coding: 0000632
VCID: 418F335F180B1816D43-8014
Address 56: Radio Labels: 8P0-035-1xx-56.lbl
Part No SW: 8P0 035 186 C HW: 8P0 035 186 C
Component: concert II EU H52 0100
Revision: 02S Serial number: AUZ2Z3E2462212
Coding: 0001005
Shop #: WSC 06435 000 00000
VCID: 326D6C93ADADB38E5D9-8067
1 Fault Found:
00858 - Connection; Radio Intermediate Frequency (IF) Output to Antenna
Amplifier
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 202
Mileage: 142896 km
Time Indication: 0
Date: 2015.10.02
Time: 17:16:58
Address 76: Park Assist Labels: 8P0-919-283.lbl
Part No SW: 8P0 919 283 A HW: 8P0 919 283 A
Component: Parkhilfe 4-Kan H09 0010
Revision: 00H09000 Serial number: 00067824820515
Coding: 0000003
VCID: 397F5BBF70DB40D69C3-806C
1 Fault Found:
01543 - Parking Aid Warning Chime (H15)
Freeze Frame:
Fault Priority: 3
Fault Frequency: 2
Reset counter: 219
Mileage: 142855 km
Time Indication: 0
Date: 2015.10.01
Time: 17:40:56
Address 7D: Aux. Heat Labels: 1K0-963-235.lbl
Part No SW: 1K0 963 235 E HW: 1K0 963 235 E
Component: PTC-Element 0404
Revision: 00800000 Serial number:
VCID: 2D577FEFB493EC7600B-8078
End ---------------------------------------------------------------------
