Hi there,
I've been trawling through this great site for info and owner experiences of the 2.5TDI B6 Cabriolet because there's a possibility I could be picking one up in the near future
I've also been trying to compare the pros and cons of the B6 2.5TDI Cabrio and the later B7 2.0TDI Cabrio...
It looks as though the 2.5TDI is probably the more prestige engine with its V6 smoothness and noise, but it has its downsides with so-so fuel economy and steep road tax. The 2.0TDI engine will be less smooth and will probably have a narrower power band, but offers better economy, cheaper road tax and also looks a little bit more modern.
There are a few other things though....
Firstly did any of the B6 2.5TDI Cabriolets come with a DPF? Or am I right in thinking these only featured in the later B7 models?
Is the 2.5TDI a PD engine like the 1.9TDI units found in the B6, and as such does it require the same special PD oil and servicing to avoid cam problems?
I've heard that the 2.0TDI engine has injector issues, but do they need the same special PD oil too?
It seems that the longlife servicing offered by AUDI dealers was a nonsense and should be avoided. Is the 2.5 more prone to damage as a result of the longer service intervals than the 2.0 unit?
What is the heavier 2.5 like on tyres? Due to the extra weight and FWD does it eat fronts? What mileage would you hope to expect out of a set of front tyres on a 2.5 with normal (i.e. not driving like a plonker) driving?
How robust are the hood motors? Can they get temperamental with age?
I've heard of great benefits by deleting the EGR on the 1.9 unit, such as marginal improvements in fuel economy and improved throttle response. Has anyone experienced the same from a 2.5 by fitting an EGR delete kit?
Are there any other things that you can do to improve the economy at all?
If I test drove some different cars, are there any obvious tell tale signs of knackered cams from how a car sounds or runs?
Should the 2.5 be serviced more often than the 2.0 due to its delicate cams?
Does the 2.5 have cambelts like the 1.9 or does it have a timing chain? If it has belts, at what age/mileage do they need changing? Am I right in thinking you need to change the water pump at the same time? Are there any other things that need doing such as tensioners too?
Do you get a spare wheel as standard?
Did they do an S-Line spec B6 2.5 or can I only expect Sport spec?
Are the B6s all 6 speed?
How much would I expect to pay for a DPF replacement pipe and remap in a B7 (just in case I ended up with a car with a clogged DPF and needed shut of it)?
What does the B7 chassis improve on over the B6 chassis and what other improvements were there on the B7 cabriolet over the outgoing b6 cabriolet, because they look even more similar than the B6 and B7 saloons do?
Are there any other common issues I should look out for on a test drive?
Apologies for the large number of questions - help with these would be really useful for me as my budget is pretty limited at around £6500 to £7000 as I will probably be opting for a car with anything up to 100000 miles on the clock. With this budget I'm going to come across a lot of tired out, unloved B7s but may find a belter with high motorway mileage. I am more likely to find some nice 2.5 B6s though and want to be sure that they are as worthy a purchase as the B7 model.
Cheers in advance...
J
J
