Yes!! Good point jaypers...Has anything been fitted that would have needed the glove box to be removed? It's an easily forgotten re-connect!
Thanks for the reply.I will be checking the glove box switch next week...I don't have the ILP and when I open the glovebox the inside light comes on.
Have you checked sensor/ switch? I am just guessing but assume there's some sort of switch that turns the light on/ off.
Try checking the hinge switch it might have worked itself loose or as above posts... has the glove box been removed for any reason?I've got the ILP and the glovebox light doesn't work, is this a "feature" cos if it is it's cr@p.
Plus the passenger side footwell led isn't working. Not good on a 9 month old car.
It is halogen in my car but I don't have ILP..Out of interest does the A3 still come with a halogen bulb in the glove box, even with ILP?
Yeah it's still a halogen 501 bulb even if you spec the Interior Light PackageOut of interest does the A3 still come with a halogen bulb in the glove box, even with ILP?
Easily changed though it seems to an LED 501 fitting bulb![]()
Gazjis..It really is easy to swap the bulb for an LED type..Try it if it doesn't light up first time just take LED out and turn it 180deg. and re fit....Any idea if the dealers would do this before collection of asked?
Gazjis..It really is easy to swap the bulb for an LED type..Try it if it doesn't light up first time just take LED out and turn it 180deg. and re fit....![]()
Thanks @veeeight, as said I can supply the kit, I can also offer upgrade kits to cars fitted with interior light packs
http://www.audi-sport.net/xf/threads/audi-a3-8v-led-inteiror-light-upgrades.259162/
Ahh thanks I missed that linkYes, the ILP already have LED puddle lamps, but these are quite frankly, pants and dim.
The link I provided in post #17 shows you the difference with the t8ups upgrade kit.
What do these offer over the ILP? Brighter bulb?
I quite like the option in the Mini ATM, where you can change the colour of the LED. Is this something you can offer?
Can supply them in other colours if you wanted to get away from white?
Can you supply red puddle lights at all ?
Yes, I have them in stock, they are £8 per pair and £2.10 uk postage. That's to replace the White LED bulb, or do you mean for the red warning lights? If so I have them too.
Trups
