  2. Dismiss Notice
Gearbox oil change advice
bigcarnut Jul 15, 2012
  1. bigcarnut
    bigcarnut New Member
    19
    Hi guys I have a 2004 a4 190 it's done 77k miles
    1st and 2nd gear seems a bit notchy I had a wee look using the search bit of the forum and seems that there has been a few people that have had the same issues
    Would it be a good idea to get the gearbox oil changed and what oil should I use to do this
    Thanks for any advice given
  2. Avatar
    snack-media
    Advertisement
  3. Mike.M
    Mike.M Well-Known Member
    2,510
    172
    I like to change gear oil every 50k miles on cars.
    Just had it done on mine, but it's only done 50k on the clock.
  4. Mike B
    Mike B Well-Known Member
    1,348
    Recently changed the oil on wifes Bora which was getting sticky in 4th and 5th and added some Molyslip which helped but you wont cure any wear without overhaul.Bora has 170k and I doubt if its been changed before.
  5. scott b
    scott b Active Member VCDS Map User
    1,248
    its a bit fiderly getting the oil back into the box as access is limited. be a ball ache to do on axle stands. luckerly i have a workshop to use
  6. Ste_Nova
    Ste_Nova Active Member
    1,214
    use a brake pressure bleeder to force the fluid in :)
  7. bigcarnut
    19
    Thanks guys
    think i will get the garage to change the oil
    should i use geniune audi stuff
  8. Turkster
    Turkster W.Bro.Paul 2.0d Q5 Quattro
    2,785
    68
    i'd not risk not using gen VAG oils mate,
  9. bigcarnut
    19
    Thanks mate genuine vag oil it is
  10. Turkster
    2,785
    68
    why not post some pics of what you do for the other's to learn from?
  11. bigcarnut
    19
    It will be the garage that's doing the oil change Paul not me
    But I will have to put a picture of the car up
  12. Avatar
    snack-media
    Advertisement
  13. cnut
    cnut Member
    150
    9
    Redline MT 90 is what I always recommend. Absolutely transformed the gearbox on my old Corrado VR6 which use to crunch and crash in 2nd. I will be doing mine soon because 2nd to 3rd gear feels a bit notchy when cold.
  14. AlexGSi2000
    AlexGSi2000 Well-Known Member VCDS Map User
    1,466
    199
    I changed mine a few months ago - made a noticeable difference.
    I used the approved oil by Fuchs.
    To fill I cut a length of hosepipe which I fed into the fill point and poured the fluid in whilst standing to the side of the car.
  15. bigcarnut
    19
    Hi thanks for the advice Alex i may just give this a go myself
