  2. Dismiss Notice
Finally fitted the RNS-D ...
vfr800 Jul 25, 2016
  1. vfr800
    vfr800 Registered User
    762
    56
    I have had this sitting in the garage for a few years. I finally ordered the Kufatec cable and fitted it today :)
    Just got to code out the TMC and make sure the other settings are correct :)
    Liam.
    ScottD3, feck_on_a_stick and VAG-Slag like this.
  2. Avatar
    snack-media
    Advertisement
  3. ayfreetee
    ayfreetee Registered User
    1,505
    296
    Nice job there bud, looks great.
  4. ayfreetee
    1,505
    296
    By the way, get some stickers for your climate buttons, makes a world of difference.
  5. vfr800
    762
    56
    Thanks.
    I have thought about the stickers ... turns out I have a few issues to iron out first ...
    RNS-D doesn't turn off / on with the ignition switch.
    Backlight illumination isn't working.
    Radio throws an error code in VCDS - about open circuit on front speaker.
    Dash clocks complain they can't talk to the radio
    Liam
  6. feck_on_a_stick
    feck_on_a_stick Registered User
    203
    78
    That looks great. I've been looking at an RNS-E for the past while, but leaning more towards getting an RNS-D for ease and less hassle fitting. They're just harder to find :(
    I recently fitted a bluetooth kit to my double din Symphony 2 and had the same issues you had (apart from VCDS which I hadn't checked). The issue was with the yellow plug that plugged in to the back of the unit. When I removed the stereo I must have overstretched the cable which had come lose in the back of the yellow plug.
  7. syncro
    syncro Registered User
    230
    79
    Don't bother with the stick on buttons, get some singledin b5 a4 facelift buttons and swap them over to your double din a3 climate unit, I've done it to mine
    ScottD3 likes this.
  8. IPG
    IPG Registered User
    1,841
    778
    Best source for them!!!
  9. ScottD3
    ScottD3 I want your faulty electronics Supporter
    15,118
    1,132
    What did you have in there before?
    If it was a symphony or later radio that used can bus for on off and illumination, you'll need to wire that up and use the TMC box for information on your cluster.
    Sent from my HTC One_M8 using Tapatalk
  10. fisher72
    fisher72 Registered User
    137
    12
    Did the rnsd ever drain your battery did you manage to get it to turn on and off with the ignition cheers
  11. ScottD3
    15,118
    1,132
    Follow the factory wiring sticker on top and you shouldn't have any issues.
    Sent from my HTC One M9 using Tapatalk
  12. Avatar
    snack-media
    Advertisement
  13. fisher72
    137
    12
    The syphony 2 uses the canbus to turn the stereo on and off but dissent seem to work in rnsd how can i get the rnsd to do it without the canbus I've read a few post about wiring the s kont up
  14. AndyM
    AndyM Registered User
    159
    S kont is wired up for RNSD
    I had it fitted from factory to my car, just took it out recently and didn't need to wire up the S Kont for an aftermarket stereo.
  15. fisher72
    137
    12
    where would i wire the s kont up to Andy
  16. <tuffty/>
    <tuffty/> Badger 5 Edition...Its all about the flow... Staff Member Moderator
    24,294
    5,571
    Fuse 37
  17. <tuffty/>
    24,294
    5,571
