Yasin M
Ok so first before I get shot down, I've tried looking for an existing thread.
P023A00 - Intermittent - Air Cooler Coolant Pump Control Circuit Open
P210000 - Intermittent - Throttle Actuator Control Motor Circuit Open (TACM)
P067400 - Static - Cylinder #4 Glow Plug Circuit Code
U014100 - Intermittent - Lost Communication With Body Control Module "A"
P191B00 - Static - Coolant Fan Control (FC) Control Module Implausible signal
P060600 - Intermittent - PCM Processor Fault
U010300 - Intermittent - Lost Communication with Gear Shift Control
U021200 - Static - Lost Communication With Steering Column Control Module
B126301 - Static - Tank lid unlock activation
U113800 - Intermittent - Anti Theft Alarm System Sensor
U113700 - Intermittent - Sirens / Alarm Horn for anti theft warning system implausible message
U111000 - Intermittent - Function Restriction Due to Communication Interruption
U006500 - Intermittent - Vehicle Communication Bus E
Check engine light came on, A friend connected his OB11 and here's a list of the following faults found.
I've searched each one but I am no better at understanding them to priorities between whats serious engine related faults and whats a VCDS bug.
To add more context, I did some VCDS tweaks and was hoping half of these are just related to them, for example I activated CC although I don't have the stalk installed so I'm guessing U021200 might me for that ?
The car seems to be running fine, apart from the engine light, If anyone has had the same errors and can give me more information it would be greatly appreciated
