Hello! Sorry for my bad english.
Skoda Superb 2012.
I try to disable rain sensor in subblock "RLS" in block "9". The result is: "Error 31: Request out of range - Coding Rejected."
At first I tried to set the values (in VCDS) the same as in this block of car:
Imp: 790
WSC: 33361
Equipment Number in VCDS I set to default ("000")
After change values in subblock "RLS" and click "do it", the program proposed to reinitialize and set standard values ("12345"), or save factory values, or set it manually.
Because the values in the module already different from zero, I click "No".
The result is still the same: "Error 31: Request out of range - Coding Rejected." ...
Then I try to set in VCDS standart "12345 / 123/ 12345" - nothing has changed...
Skoda Superb 2012.
Imp: 790
WSC: 33361
