so i had the day off today so i set about installing my new lowering springs and my new big brake setup... talk about falling at the first hurdle...
i put the breaker bar on the main drive bolt as you do....gave it a twist and it loosened. normally after twisting these a bit they screw out fairly hand but no. after 2 or 3 more 90 degree turns it was clear that the bolt is twisting and threading insde the drive shaft. i decided to abort and go home and have a cry. i see no option but to angle grind the bolts off and replace the cv joints.
i always said with this car i would use genuine parts but audi are quoting me €125 per cv joint.
is there any suppliers who provide an oem standard cv joint that wont fall apart?
cheers
cheers
