Morning Gents,
I've had the eml come on and a read revealed the following code
1 Fault Found:
16727 - Camshaft Position Sensor (G40)
P0343 - 35-00 - Signal too High
Readiness: 0110 1101
First happened a couple of months ago, cleared it and it came back on 5 days later, read it again and it did have some other codes on the same area but for the life of me i can't find the log, but i remember thinking ooooh perhaps they indicate that its a tooth out or something else along those lines.
Anyway they didn't come back for a month or so and now its come back twice but only the error i've posted above nothing else.
So...
1 I suppose the easiest thing is to change the sensor first and see what happens?
2 One thing i wanted to check is i've been having an issue where intermittently there's been a strong fuel smell and its blown a bit extra greyish exhaust fumes and i could never find a pattern. I think now i have, it seems to only happen when the eml light is on and i get this error. Could they be related? I'm thinking that because of the cam error there might not be the proper combustion of fuel?
3 To save me some googling and also i'd rather it from a source i trust does anybody know the part number for the camshaft position sensor?
4 And to be a bit cheeky, just while i'm here the part number for a rear ABS wheel speed sensor?
Its a 2001 A3 quattro sort 1.8T - ARY engine code
Cheers guys and gals
1 Fault Found:
So...
