lewis.bates.73
Hi guys I swapped my Audi a3 diesel for a 1.8t a3 and I noticed there was no engine warning light when I turned the ignition on so I carried on with the swap and took it work today and plugged it in to see if it had any issues.
I got 3 codes
It's had a cambelt and cam chain recently by the previous owner and to me runs all fine but as I've been browsing about these problems I've noticed that it sounds like a common problem with the timing?
It starts fine
It idles fine
Boost is ok I think (always had diesels)
There's no obvious noise that points to anything
It's a 1.8t AUM engine with 143000 miles
Could anyone shed any light on this
1. If the timing is out could it effect the boost?
2. Will it be ok to keep running it or should I strip it IMMEDIATELY
3. What about the faults with my coils could that be anything to do with the timing or do I just replace them?
4. Where is the engine warning light ment to be on here the picture of the dash is below
Thanks for you help guys so far not having much luck with it and I only swapped yesterday
This is my car by the way I'll post pictures now
I got 3 codes
It starts fine
It idles fine
