So recently got a new car. Audi A3 2005 3.2l V6 Quattro manual 3dr. I believe it's the 8P1 chassis but could be wrong.
So everytime I start the car (without the headlights on) it says I have a rear bulb out, usually the right but sometimes the left or both, when actually they are both working.
Now when I turn the headlights on it also says the parking light is out, which is working, then it says the right rear indicator bulb is out and it does actually stop working and the side and front indicator start flashing a lot faster. The indicator works when the headlights are turned off.
I could ignore the bulb out messages but it's the faulty indicator that I need to fix.
Should mention as well that I noticed the headlights have different bulb fixings so I guess a headlight has been replaced in the past. One has spring retaining wire and the other one you can kind of just pull out and push back in.
Anyone have any ideas?
