Over the weekend I replaced my front discs and pads on my 2004 A4 Avant 190 Bex.
All went fine and replaced with Drilled and Grooved Black Diamond disks and Green stuff pads.
The car has been fitted with TEIN super street coilovers which have been great; I have not set them as slammed, more a sporty stance with plenty of threads left if I want to go lower in the future.
The problem is that since I replaced the Pads/Discs yesterday I have had the dreaded knocking/loose clunky noise going at a low speed from the coilovers.
I fitted the pads/disc while I have the front of the car on axle stands.
I had noticed the knocking/clunky very slightly before I changed the brakes but it has got a lot worse since the weekend after installing the pads/discs.
Anybody have any ideas on why and what I can do/check to eliminate that annoying knocking/loose clunky noise?
I know the brake install is OK as I have checked and double checked it, maybe something has not aligned correctly when the car was taken off the axle stands and under load??
Any suggestions are welcome
