a4b6awx
Hi Guys,
advice needed;
Fault initially started after having the oil and gunk washed off from the underside of the car. It was washed off lightly with degreaser and a hose, not a pressure washer, but may have got somewhere and shorted/damaged sensor?
The car was juddering with ESP light coming on solid over 1800rpm, but would go out if left to idle.
Drove car home from said cleaning, first 3 miles, kept under 2k rpm due to juddering and snatching like clutch was being let in an out. After few miles with blowers on full heat, got boost back, would drive spirited without issue.
That was a couple days ago. today, had the bungs let out as heard slooshing when reversed, didn't drive car, literally heard the water, parked it up. Battery out, Bungs out, ECU case off, silicone around ecu box seal, then in reverse order back together.
Not inclined to think its vacuum hose related as we had boost back after the first occurrence, Brake Pedal switch in vagcom shows 0 1 1 when pressed, and with clutch down at same time as brake pedal shows 1 1 1, so assume this is fully functional
Scan before clear is as follows:
Address 01: Engine Labels: 038-906-019-AVF.lbl
Part No: 038 906 019 JQ
Component: 1,9l R4 EDC 0000SG 1570
Coding: 00002
Shop #: WSC 63351
VCID: 6FED66BB2D9D05FEE2-4B18
WAUZZZ8E93A280918 AUZ6Z0B0376230
4 Faults Found:
17994 - Engine Mount Solenoid Valves (N144/N145)
P1586 - 35-10 - Short to Plus - Intermittent
16705 - Engine Speed Sensor (G28)
P0321 - 35-10 - Implausible Signal - Intermittent
17569 - Manifold Temp Sensor (G72)
P1161 - 35-00 - Open or Short to Plus
17564 - Manifold Pressure Sensor (G71)
P1156 - 35-00 - Open/Short to Ground
Readiness: 0 0 X X X
Address 03: ABS Brakes Labels: 8E0-614-517.lbl
Part No: 8E0 614 517
Component: ABS/ESP front 1729
Coding: 04255
Shop #: WSC 06435
VCID: 65C10493FF61CFAE98-515A
2 Faults Found:
18266 - Engine Speed Signal
P1858 - 35-10 - Error Message from ECU - Intermittent
01826 - Sensor for Steering Angle (G85); Supply Voltage Terminal 30
35-00 - -
Address 08: Auto HVAC Labels: 8E0-820-043.lbl
Part No: 8E0 820 043 K
Component: A4 Klimaautomat 1116
Coding: 00000
Shop #: WSC 63351
VCID: 295948A3D3F92BCE7C-5178
3 Faults Found:
01810 - Actuating Motor for Temperature Flap; Right (V159)
41-00 - Blocked or No Voltage
00716 - Air recirculation Flap Positioning Motor (V113)
00819 - High Pressure Sensor (G65)
07-10 - Signal too Low - Intermittent
After Clear (Started, revved, but not yet driven):
Coding: 00002
Shop #: WSC 63351
1 Fault Found:
Readiness: 0 0 X X X -------------------------------------------------------------------------------
Coding: 04255
Shop #: WSC 06435
VCID: 65C10493FF61CFAE98-513C
1 Fault Found:
35-00 - -
Previous owner stated he removed the mounts solenoids/along these lines so not fussed about this as it was present prior to this issue.
We are inclined to lean more towards wiring or in the unlikely event a sensor let go, but don't want to meaninglessly replace things.
For reference, the steering angle sensor will not read in VCDS measuring blocks, perhaps it needs to be logged in first?
We are all ears as our mobile mechanic is at a loss, and as he's a friend and funds tight, inclined to stick with him.
advice needed;
Coding: 00002
Shop #: WSC 63351
4 Faults Found:
Coding: 04255
Shop #: WSC 06435
2 Faults Found:
35-00 - -
Coding: 00000
Shop #: WSC 63351
3 Faults Found:
Coding: 00002
Shop #: WSC 63351
1 Fault Found:
Coding: 04255
Shop #: WSC 06435
1 Fault Found:
35-00 - -
