Audi S3 8P Exhaust system!?
Joshua Ward
Hi all,
i am looking for a relatively cheap exhaust (£400-£800) for my car and was wondering if anyone knew of a good custom exhaust company or an off the shelf exhaust that sounds really low and burbly? :highly amused:
really like the sound of the deeper exhaust notes.
thanks.
i heard of place up in leeds called Prestige Custom Exhausts but would love to hear some good ones anywhere close by ?
prt57
I think you are going to struggle to find something new that is decent quality within your budget. However, you may be lucky and spot a 2nd hand system. Be aware that if you change the downpipe to will need a remap to remove the light that will appear on your dashboard.
The cheapest option that does what you want is a resonator delete. Be careful as some may make the exhaust drone at motorway speeds
Konstantinos
What about stock exhaust. Is it sufficient for full stage 1 setup?
Removing the resonator will improve the performance on a stock car?
prt57
On an S3, the main restriction is the downpipe and standard cats. If that is replaced with 76mm pipework and a free flowing sports cat and remapped you will see about 330 BHP. Maybe more if you have a free flowing intake.
The whole idea with a stage 1 remap is that no hardware changes are made. However, if you do change components, a custom remapper would be able to fine tune to get the best out of your car.
My son has a resonator delete on a TT and he thinks it might be slightly more responsive.
Konstantinos
Have the intake already, I will go for the downpipe soon and then tune it to see the results!
Thanks for the input!
ch1z64
C'mon you's bhoy's in Green
Silver Supporter
You can take your S3 to Stage 2 with just stock going by what other more experienced members have mentioned on here ,
Daveyonthemove
Well-Known Member
Mine has a resonator delete. Much nicer on cold start, and I get a few crackles on gear changes under hard acceleration, but normal driving is fine. No drone.
Not sure if this link will work, but I uploaded this video to my Instagram last weekend.
samuelh_888
Stage 2 requires a downpipe and intake. @Joshua Ward if you don’t want to spend £’000 then speak to Pipewerx for one of their downpipes. They are very good quality and are one of the go-to options for the 8L. They do an 8P dp too. This would then allow your to upgrade the rest of the system later if so desired.
Search eBay - and yes, they do motorcycle systems too, this is where they made their name. https://rover.ebay.com/rover/0/0/0?mpre=https://www.ebay.co.uk/ulk/itm/301548283456
