Ashleymark
Hi all,
i have used this forum without the need to register for a while now. But now I am completely stuck and can't find answer via searching.
Basically my radiator fan is spinning at all times and speeds up with revs ( it sounds like a fighter jet). I have replaced viscous fan coupling as old one seemed tight, but this made no difference. If you stop fan with belt or cable tie it stops it from spinning but car does not overheat or go past 90.c. The actual pulley that drives the fan seems tight to move. I have read that possibly a failed thermostat or coolant temp sensor may cause these issues? Also After 2 hours of driving coolant is still only Luke warm, but temp gauge reads 90.c.
Sorry for long post just wanted to give as much info as possible.
