My car seems to have developed a vibration that while not serious is damn annoying, it occurs in any gear as well as in neutral but always at the same point in the rev range regardless of whether accelerating or decelerating.
The vibration feels more like a buzzing vibration (if that makes sense) that can be felt through the steering wheel & pedals that starts at around 1400rpm & completely disappears at 1900rpm. Below 1400rpm & above 1900rpm there are no shakes or wobbles & the engine is smooth as silk, the weirdest part is that turning the steering wheel does sometimes alter the feel of the vibration in the steering wheel even in neutral.
So far I've checked wheel balancing, swapped the wheels round (not that I can figure how that would affect the car at idle), checked the injectors on VCDS which appear to be operating & balancing ok, + a visual check on the upper engine mounts all appears to be ok.
Any ideas where I should be looking next?
