Alignment
Behind The Bins
Ok so collected new RS3 yesterday but I'm not sure if the steering wheel sits slightly to the right when steering straight ahead, even allowing for camber
If I look at the gear change paddles and the bottom of the wheel when steering straight ahead the wheel appears to sitting to the right marginally, but if I shift my buttocks to the right so I'm sitting closer to the window all seems ok.
When driving on a reverse camber I should be steering slightly left to allow for this but the wheel looks straight, obviously when driving on a normal camber I am steering slightly right but more in my opinion that I should be
So my question is... Is the driving position off centre causing an optical illusion or do I need an alignment?
T
Tristan2
Guest
Mines the same, as was my S3
T
T-800
Guest
Probably needs alignment.
I have mine done the week I buy them.
Guy who does it says he’s seen brand new cars out from the factory.
Just find a guy who knows how to operate his machine properly.
Look here
https://www.alignmycar.co.uk
T
Tristan2
Guest
So have I,just waiting on a result on the matter before I go to Audi
T
T-800
Guest
Posssibly best biting the bullet and paying to have it done myself, I just dont trust them
I would....
Keep it away from Audi in my opinion.
You’ll not get any joy anyway as they’ll say you hit potholes driving it.
At least if you have it done yourself you know it’ll be correct and in most cases you can watch them do the work.
AudiNutta
Moderator
Staff member
Moderator
Gold Supporter
It’s normal to be slightly to the right, I complained the same with my S3 and it ended go being aligned 3/4 times for various problems and always went back the same.
My RS3 is the same, slightly to the right.
AudiNutta
Moderator
Staff member
Moderator
Gold Supporter
Surely this is not acceptable
It’s the difference between not being acceptable and how the car was designed to be set up at the factory.
The Audi centre enter your reg and get the specs for that car and nothing else.
Behind The Bins
But what I dont understand is set the steering wheel straight, clamp it, then adjust the alignment, I seen it done on Hunter machines with a great result. The alignment doesnt care where the steering wheel is positioned
AudiNutta
Moderator
Staff member
Moderator
Gold Supporter
True, it’s just how Audi set them up repeatedly regardless of how and where the clamp is.
T
T-800
Guest
If it's done correctly the steering wheel will be central......
Had every one of my cars done as soon as they are bought, never had an issue with the steering wheel being off centre.....
The guy that does mine lets me go for a drive after he has finished the alignment to make sure I'm happy with the wheel position, if i'm not he adjusts it until i am.
Behind The Bins
I'm booking mine in at a place with a hunter and sending Audi the bill, not expecting them to pay it but I can vent my displeasure, emailed dealer immediately after collection to register fault
AudiNutta
Moderator
Staff member
Moderator
Gold Supporter
Audi Warranty pays for any alignment changes in the first 6 months from what I’ve read.... but they 110% won’t pay elsewhere when they kit is more than up to it, all Hunter as far as I’m aware.
Prepare to be surprised when you see the overall alignment, my S3 was nearly all in the red at 4000 miles. I’m toying with the idea of having the RS3 setup at the specialist, £90 a pop. One thing at a time.....
Also looking into a catch can.
p@olo
I have the same issue, only my steering wheel sits slightly to the left.
Having a LHD car, I’m wondering if it could be related to the road inclination
AudiNutta
Moderator
Staff member
Moderator
Gold Supporter
I’m having a service at my specialist on the 26th, getting them to do a proper Hunter alignment for £90... got a feeling they offer different kinds of setups too.
T
Tristan2
Guest
Who is the specialist mate?
AudiNutta
Moderator
Staff member
Moderator
Gold Supporter
Indigo-GT, real good boys down there that really know their stuff. Once you’re a customer, you will receive neverending support.
Based in Ystrad Mynach, South Wales.
Splathead
I hadn't noticed that my steering wheel was slightly to the left. Now it is all that I can see. :grimacing:
Contemplating moving the wheel one spline to the right for the moment.
T
T-800
Guest
You'll confuse the steering angle sensor by doing that..........
AudiNutta
Moderator
Staff member
Moderator
Gold Supporter
Just have the alignment done properly.
Splathead
Thanks for the heads-up but it is easy to recalibrate.
I may try and get it done by the dealer but I really can't be bothered with the battle of getting past the "gatekeepers". I'm getting quite a collection of niggles and not even up to 1500 miles yet.
Behind The Bins
I have a few niggles also, going in to have them sorted, going to wait on the ticking exhaust as the part number is the same
AudiNutta
Moderator
Staff member
Moderator
Gold Supporter
Is the wheel dead straight ahead now?
Send bill to Audi?
I haven’t had it done yet, being done Monday.
Can’t send the bill to Audi, didn’t give them the chance to sort it. They won’t just take it in straight away, they will want to see a tracking issue with the car pulling to either side before they do any alignment anyway... not worth the battle and a day without my car.
But on a side note it does say that Audi Warranty covers alignment issues but only for 6 months.
