Now this thread is either going to put my mind at rest or not......depending on your responses.
I have a noise that I can't seem to reliably reproduce, in order to demonstrate to the dealer, that is a rotational click/crunch/clunk as you pull away slowly after the car has been parked up for a while.
I thought it was wheel bearing, CV joint or differential. But driving round and round in tight circles either backwards, forwards, left or right does not do it.
However if I park up at work in the morning, then drive out slowly I get the noise as I trundle through the smooth car park (which probably helps me hear it), on what appears to be the 1st and 2nd rotation of the wheel. I can also feel it through the pedals.
But this does not happen, or at least it's not audible/noticeable every time.
If it is going to happen the car doesn't necessarily have to be left for long, because it done it the other day after just 20-30 mins stop.
I then found these links, which seems to explain it as part of the ABS Self-Test. So I was wondering if anyone else experiences it
http://www.honestjohn.co.uk/forum/post/index.htm?t=30969
http://www.pistonheads.com/gassing/topic.asp?h=0&t=571601
http://www.airliners.net/aviation-forums/non_aviation/read.main/2135436/
http://tech.bentleypublishers.com/thread.jspa?threadID=478
http://www.tyresmoke.net/forum/topic/48502-a4-tdi-problems/
Fix ? : http://www.audiworld.com/forums/s4-rs4-b5-platform-discussion-6/abs-self-test-brake-noise-"fix"-sorta-1368781/
