I'm having a bit of a nightmare with my 2007 A5 at the moment .
In January I started getting a random ESP/ABS light - it went in for a checkup and the tech diagnosed it as a faulty ABS module.
We took the ABS module out and sent it off the ECU Testing, but they bench tested it and said it was fine. The tech then continuity tested the wiring and it checked out - there wasn't really anywhere else to go and he felt the symptoms all pointed to a faulty ABS module, so I ordered a second hand module and the plan was to fit to check but now with lockdown that's had to go on hold for the foreseeable.
I also had a wheel speed sensor go, which was replaced during the diagnostics - the faults for that are hanging about, but my cruise control is working (which is didn't when the sensor was broken) so I don't know if those codes aren't clearing because of the lack of communication with the ABS module.
I did a scan a few days ago though and noticed i've now got a lot of faults relating to the parking brake module as well which is a new development.
I'm a bit concerned various modules are going to start cacking themselves and it's just going to be chasing problems round the car from now on. Is it possible the parking brake issues are related to the ABS?
I cleared the codes and rescanned today so these are the recurring ones - any advice or comments appreciate as I'm getting a bit concerned about the old wagon.
It's going back into the garage once lockdown is over, but I'm keen to see if anyone else has had similar before (for peace of mind more than anything)?
Code:
Date: 2020-04-20 17:23
VIN: WAUZZZ8T38A01****
Car: Audi A5
Year: 2008
Body type: Coupe
Engine: CAPA 176 kW (240 HP) 3.0 l
Mileage: 120310 KM
01 Engine
System description: 3.0TDI EDC17
Software number: 8K0907401
Software version: 0009
Hardware number: 8K0907401
Hardware version: H01
ODX name: EV_ECM30LTDIA5
ODX version: A01010
Long coding: 01140023180F0118
Trouble codes:
U101700 - ABS brake control module Read out DTC
static
static
P161A00 - Glow plug cylinder 1 Open circuit
static
P161B00 - Glow plug cylinder 2 Open circuit
static
P161C00 - Glow plug cylinder 3 Open circuit
static
P161D00 - Glow plug cylinder 4 Open circuit
static
03 Brakes
System description: ESP8 quattro
Software number: 8K0907379J
Software version: 0190
Hardware number: 8K0907379J
Hardware version: H03
Serial number: --------------
Long coding: 1B4500
Trouble codes:
00290 - Left rear ABS wheel speed sensor Electrical error in circuit
static
00473 - Electronic parking brake control module -J540 Please read DTC
static
03265 - Suspension sensors data bus No signal/communication
static
00493 - ESP-Sensor unit No signal/communication
static
04 Steering Angle Sensor
Trouble codes:
No trouble codes found
05 Keyless System
System description: BCM2.01
Software number: 8K0907289D
Software version: 0253
Hardware number: 8K0907289D
Hardware version: H37
Long coding: 071000
Subsystems:
System description: ELVAUDIB8
Software number: 8K0905852A
Software version: 0039
Hardware version: H34
Serial number: 0207000000504008
Trouble codes:
02823 - Locking requirements for Steering Column Lock not met
static
01330 - Comfort system central control module Please read DTC
static
06 Passenger Seat
System description: MEM-BFS
Software number: 8T0959760
Software version: 0027
Hardware number: 8T0959760
Hardware version: H08
Serial number: 00001001022784
Long coding: 08217025002444111000
Trouble codes:
07 Display
System description: Interfacebox H43
Software number: 8T0035729
Software version: 3250
Hardware number: 4E0035729
Serial number: 329HX077517066
Coding: 0005002
Subsystems:
System description: E0380 BedienteilH07
Software number: 8T0919609C
Software version: 0100
Trouble codes:
01043 - Control module: Incorrect Software version
static
08 Air Conditioning
System description: KLIMA 3 ZONEN
Software number: 8K2820043AD
Software version: 0123
Hardware number: 8K2820043AD
Hardware version: H04
Serial number: 01060220121166
Long coding: 2606000000
Trouble codes:
03037 - Rear temperature selection potentiometer Open circuit/short circuit to B+
static
09 Central Electrics
System description: BCM1 1.0
Software number: 8K0907063D
Hardware number: 8K0907279D
Hardware version: H19
Serial number: 00000000031424
Long coding: 2600D0910014AF010009000300005D5D0F19038800010141000000
Subsystems:
System description: WWS 090807
Software number: 8T2955119B
Software version: 0040
Hardware version: H11
Serial number: SWFBIE 0000106
Long coding: 00FD11
System description: RLS
Software number: 8T0955559
Software version: 0001
Hardware version: H12
Serial number: 10012578
Long coding: 02532C
System description: E1 - LDS
Software number: 8K0941531G
Software version: 0070
Hardware version: H07
Serial number: 00000000000607070944
Trouble codes:
0E Media Player
System description: MP3-Changer H42
Software number: 8T2035110A
Software version: 0350
Hardware number: 8T2035110A
Hardware version: 000
Serial number: AUZ5ZBG4511823
Trouble codes:
10 Parking Assistance
System description: PARKHILFE 8K
Software number: 8K0919475A
Software version: 0003
Hardware number: 8K0919475A
Hardware version: H06
Serial number: 46230719905946
Long coding: 100001
Trouble codes:
15 Airbag
System description: AirbagVW-AU10
Software number: 8K0959655
Software version: 0334
Hardware number: 8K0959655
Hardware version: H21
Serial number: 0038GD0875N/
ODX name: EV_AirbaECUVWAUDI010
ODX version: A02001
Long coding: 30323232333030303030554A305238543053
Trouble codes:
16 Steering Column
System description: Lenks.Modul
Software number: 8K0953568B
Software version: 0011
Hardware number: 8K0953568B
Hardware version: H09
Serial number: 90315GGU0001Z
Long coding: 000016
Subsystems:
System description: E221 - MFL
Software version: 0004
Trouble codes:
01316 - Brake control module Please read DTC
static
17 Dashboard
System description: KOMBIINSTR.
Software number: 8T0920980M
Software version: 0212
Hardware number: 8T0920980M
Serial number: 6C120U987
Long coding: 2305010002002600010000
Trouble codes:
19 Gateway
System description: GW-BEM 4CAN-M
Software number: 8T0907468F
Software version: 0084
Hardware number: 8T0907468F
Serial number: 3200E077268069
Long coding: 000003
Subsystems:
System description: J367-BDM
Software number: 8K0915181
Software version: 0150
Serial number: 17002CC3230707
Trouble codes:
03041 - Energy management active
Intermittent
1E Media Player 2
System description: SG ext.Player
Software number: 4E0035785A
Software version: 0530
Hardware number: 4E0035785A
Trouble codes:
36 Driver Seat
System description: MEM-FS
Serial number: 00001001022434
Long coding: 08397B25002444111000
Trouble codes:
37 Navigation
System description: MNS ECE H50
Software number: 4E0910888P
Software version: 1060
Hardware number: 4E0919887M
Serial number: 333GZ077515688
Trouble codes:
42 Driver Door
System description: TSG FA
Software number: 8K0959793
Software version: 0149
Hardware number: 8K0959793
Serial number: 0iya �00 áa¤�
Long coding: 011C12225E012201
Trouble codes:
46 Comfort System
Serial number: 0105137766
Long coding: 011B0E80003904C1002000
Subsystems:
System description: DWA-Sensor
Software number: 8K0951177
Software version: 0030
Hardware version: H02
System description: LIN BACKUP HO
Software number: 1K0951605C
Software version: 1301
Trouble codes:
03123 - Terminal 30 - 2 Open circuit
Intermittent
47 Sound System
System description: DSP STD
Software number: 8T0035223P
Software version: 0250
Hardware number: 8T0035223A
Long coding: 010101
Trouble codes:
00417 - Left front DSP mid-bass speaker Open circuit
static
00418 - Right front DSP mid-bass speaker Open circuit
static
52 Passenger Door
System description: TSG BF
Software number: 8K0959792
Hardware number: 8K0959792
Serial number: 0 b �00 áa¤�
Trouble codes:
53 Parking Brake
System description: EPB Audi B8
Software number: 8K0907801C
Hardware number: 8K0907801C
Serial number: 00000000015390
Trouble codes:
static
55 Headlight Regulation
System description: Dynamische LWR H01
Software number: 8K0907357
Software version: 0010
Coding: 0000002
Trouble codes:
static
56 Radio
System description: TUNER EU/US/RDW H42
Software number: 4E0910541Q
Software version: 0620
Hardware number: 4F0035541L
Serial number: 336HT077514823
Coding: 0000001
Trouble codes:
77 Telephone
System description: Handyvorb2 H18
Software number: 4E0910336J
Software version: 0810
Hardware number: 4E0862335
Serial number: 00000005001455
Coding: 0010920
Trouble codes:
