Left (1/3) section of backrest and right (2/3) section of backrest without centre armrest - exploded view of components
1 - Mounting bracket (right-side)
2 - Latch (right-side)
q Removing and installing → Chapter
3 - Centre bracket
4 - Clip
5 - Trim cap
6 - Bolt, 15 Nm
7 - Mounting bracket (left-side)
8 - Pivot pin (left-side)
9 - Latch (left-side)
10 - Left (1/3) section of backrest
11 - Right (2/3) section of backrest
q without centre armrest
12 - Pivot pin (right-side)
Right (2/3) section of backrest with centre armrest - exploded view of components
1 - Cup holder
q In centre armrest
2 - Centre armrest
3 - Belt buckle
4 - Bearing
q For backrest
5 - 55 Nm
6 - Three-point seat belt (rear)
7 - Backrest latch
8 - 12 Nm
9 - Latch trim
q For backrest latch
10 - Head restraint guide
11 - Head restraint guide
q With release tab
12 - Belt guide
q For three-point seat belt
13 - Covering frame
q Cannot be removed without becoming damaged
14 - Right (2/3) section of backrest
15 - Foam wedge
16 - Cover and padding
17 - Load-through hatch
18 - 10 Nm
q With plastic ring
q Cannot be renewed as a separate unit
19 - Padding
q For centre armrest
Removing and installing left (1/3) backrest section or right (2/3) backrest section
Removing
– Remove luggage compartment floor covering.
– Release retaining clips -arrows- at cover cap.
– Remove bolt -1- and detach retaining clip -2- in direction of -arrow-.
– Lift backrest out of mounting (centre).
– Pull backrest out of outer pivot pin towards centre of vehicle.
Installing
Install in reverse order of removal.
I hope this helps...
