URGENT HELP GUYS - FAULT CODES
ravi
Hi Guys,
Last night I experience issues with my motor and serious juddering when driving and at idle.
I’ve just scanned the system and the following fault codes appeared:-
17956-163
Boost pressure regulation valve (N75) open circuit
P1548
16486
Mass Air flow sensor (G70) – Signal too low
P0102
Has anyone experienced these?
I replaced my MAF about a year ago and N75 6 months ago.
What do I do? How can I find out where the problem is - MAF or N75?
Help!
rav
i replaced the the n75 and disconnected the maf but no change.
I reset the codes and they didnt appear again
How about the coilpacks - would a fault with the coil -packs register a fault code?
its weird as the problem is there but still no fault code
I would check vacuum pipes under the inlet mani if you are still having issues...
If you have a registered version of VAGCOM see what block 032 says after a run (with the engine idling). These are the adaption values... both should be as close to 0% otherwise this would indicate a prob... high postive value in the first box would indicate a vacuum leak..
Thanks Tufty. I dont have VAGCOM, i'm using a Sealey fault finding tool. I will check the vacuum pipes.
