8V FL Rear camera and rear PDC
Golfather
Hi all
Currently have rear PDC from factory on a 8V FL
Understand noone can activate the PDC display on the MMI, other than Hazzy Dayz which requires a replacement module.
If a rear view camera is installed, will the rear PDC Display be shown as well as the gridlines of the camera?
AlS3BE
Hi all
nope. I got the rear camera retrofitted by @DJAlix on here and only ways are hazzydays way or get front sensors to get the PDC lines.
Hoping someone will figure it out soon.
Golfather
So if I get the front sensors, will a new PDC module be required? Or do they slot and wire into the existing rear sensor module
DJAlix
VAG Car Coding™ Limited
Site Sponsor
Gold Supporter
VAG Can Professional
ODIS (Offboard Diagnostic System)
Need new supporting hardware also. Should also get a new internal button panel.
DJAlix
Site Sponsor
Gold Supporter
Maybe a few of us should chip in and get the hazzydays one and reverse engineer it :wink::whistle2:
Nothing to reverse engineer, just retrofit an 8K module
Khufu
this is my old 8K module. It displays the front and rear markers and trajectory but you need the front sensors and speaker for it to work.
Reactions: NHN
1Rockape
You can get the overlay up for rears only if you go non oem camera which in my opinion is better as fills the entire screen and loiks identical in the boot handle .
Sent from my SM-G950F using Tapatalk
AlS3BE
tried that and the screen just shows errors as there’s no front sensors. Had the module from my mates Seat.
Trying to figure out a way to get the display with just the rear sensors.
DJAlix
Site Sponsor
Gold Supporter
Guessing you just plugged it in without re-parameterising....
Grahame53
Hi
Saw your video on YouTube regarding Hacks being done to get items working on a car only to lose the functionality if you have an update performed at a VAG dealership for warranty purposes.
Also saw this thread which is of interest as Reverse Park Camera addition is on my to do list. My S3 is 2020MY and has PDC as part of Tech Pack Advanced but I was unable to specify Reverse Park Camera at point of build as Audi did not make the option available. Challenged this at the time with the dealer but definitely not available to order to be built that way.
So question for you if you would be kind enough to help is;
1. Can I have a legitimate RPC fitted?
2. Would it remain coded if my car was to have an Audi dealer do any programming/coding?
3. Could you do it and the obvious, how much please?
Regards
Grahame
DJAlix
Site Sponsor
Gold Supporter
Hi
Regards
Grahame
While some items can be retrofit legitimately, ie installed and then added to your vehicles design database, a reversing camera is not such an item. The retrofit however does not require any "hacking" in order to work, just conventional coding and adaptation + physical installation. This and any coding related modification, for example beep on lock or mirror dip in reverse gear, has the potential to be wiped during any Audi service procedure or software update because said modifications are not recorded. Nothing anyone can do about this, its the nature of the game. I offer a free return to base re-coding service for retrofits, and ask a small admin charge for software modifications.
Not for the A3.
Yes and no, all depends on what works were being done for example if your MMI was updated then the camera would need to be reconfigured. If you had an update to your gearbox then no retrofit should be touched.
£395 to £445 depending on your vehicle and specification for High Line Camera (top of the range). Genuine Parts with 2 years warranty.
DJAlix
Site Sponsor
Gold Supporter
@DJAlix. Can you parameterise a new/used 8k module so folk with just rear sensors can get the parking distance lines?
potentially, depends on the part number
Grahame53
Thank you for the rapid response and detailed explanation contained in your reply.
I would be delighted to have you carry out this work for me. I have some holiday due in early March, exact date TBC, so how much lead time would you require?
I can provide Reg No or VIN or both as required and happy to pay a deposit as and when needed. I live in Norfolk and would like to drive down to have it done with you and return same day if this is feasible assuming I arrived no later than 10.30am on the pre arranged day?
Should I communicate with you further giving sensitive details I presume it would be better to email using the hello@vagcarcoding.com address?
Regards
Grahame
DJAlix
Site Sponsor
Gold Supporter
Regards
Grahame
Best to give me a call on 07950 737 899. can run through all the details and answer any questions which you might have. I have customers travel from all over the EU and all are more than welcome to pop in to London for the day and leave the vehicle with me.
Grahame53
Brilliant I will get dates sorted for March and call you to get it arranged. Many thanks
DJAlix
Site Sponsor
Gold Supporter
Is this something you want to entertain doing for us or is it too much hassle? Mate breaks cars for a living so have access to some modules.
If you can source a 5QA 919 294 / A then should be able to do it. You will need a little additional coding once module is fitted.
Golfather
I have a 5qa919294b if that can be done?
Not installed yet but from an a3 with front and rear
Mine just has rear
DJAlix
Site Sponsor
Gold Supporter
will have a look. Does the A at the end important? Or any letter will do?
Not important but would be good if you could locate no letter or an A
