What a job that was! nice and easy on all the other cars ive had, this was a pig! but had to be done as it nearly didnt start at all this morning. I couldnt afford a top range battery unfortunately, so i went for a Bosch S3, are these ok? 3 year warranty anyway so not overly worried. Unfortunately didnt seem to solve my brake warning on starting, although need to give this more time so that the battery can be properly charged. If that fails, the audi fix of a new relay to fix this problem..is it something that can be done DIY and does anyone have any instructions?
Thanks a lot, car is getting there, So far changed: cambelt, water pump, oil strainer, thermostat, temp sender, battery, snub mount, PAS pump, aux belt tensioner. Got to do: Brakes, CV joint and solve this annoying vibration over bumps, potholes and rough ground. All good fun!
J7USS - i know you said i probably should have done a more thorough check of the ar, but considering how much it cost, im more than happy to do all this work, and once its done, itll be mint again i hope! Then i can get on with the fun parts!
