s4marsh
when i got back from a drive earlier i was under the bonnet doing my routine checks as you do and started thinking about the heat that was in the boost pipes, airbox and all the pipework onwards from there and was wondering how much of the heat will have been generated by the flow/friction of air inside the pipes and how much was heat soak from the engine bay temps as the car was parked up with no airflow..leading me onto the idea of some home made pipe covers and heatsheilds especially round the turbos + downpipes and insulate the airbox and intake as best as i can from the radiated heat or is the majority of heat from the air flow itself and would i be then trapping the heat in making the intake temps rise even further? i have a load of glass cloth blanket that i use in the furnace building industry which will be identical if not better than some of the stuff motorsport places selling. any thoughts on the idea??? i was maybe thinking of bonding it to some aluminium foil with the special fireproof glue thats used with the cloth to make rigid heatshields too and can make all sorts of shapes like doing fibreglass work. i have plenty if anyone wants to try something like this???
