DreA3Turbo
DreA3Turbo
Long time away from the forum....but have decided to show the A3 some love again
So...in with my 1st question....
I'm thinking about getting involved in a liquidS3 and am aware that some of the data may not populate based on the engine code that I have. For those that own AGU engines and also vagcom's, can you confirm whether or not you are able to pull the following data.....(i understand that if it can be pulled with a vagcom then it will display with a liquid)
Engine Power
Torque
Boost Pressure
Mass Air Flow
Air Fuel Ratio
Air intake Temp
Exhaust Temp
Dyno Plot
Timing Correction Plot
Speed timing
Fault Codes
The A3 is going in for some AP coilovers, powerflex bits, Forge spacers, TIP and some other goodies at AMD tomorrow so I expect I will be lighting up the forums with questions and pictures very shortly!!!
Cheers in advance....
Engine Power
Torque
Boost Pressure
Mass Air Flow
Air Fuel Ratio
Air intake Temp
Exhaust Temp
Dyno Plot
Speed timing
Fault Codes
