Hi all,has anyone got a link to a vid with an 8p s3 running a forge dump valve by any chance as i want to get a D/V fitted but not sure which one to go with,any suggestions would be appreciated cheers.
Surely the S3 has a dump valve already? Why would you want to fit another one, unless you wanted that rather chavvy 'psssssst' sound. Leave it for the Scooby/Evo brigade IMHO .
Phil
Do they sound good sarah and do they affect the performance at all?Hi
The 2.0T ones can run the dump valves OK
No worries on that one
Have a look on Forge Motorsports web site , as I do know they do have quite a bit of info on there , they also do the adjustable one too
Sarah
Meant a dump valve boggysvBy D/V do you mean dump valve or diverter valve?
Dump valves dont work well with our engines/computer afaik, but it makes chicks wet...so..it's your call in the end of the day.
?? ...ermm,how come mine makes this phsssst noise (i don't think its quite as noticable as the Scoobies and Evo's)
Im running the standard OE diverter,but the noise started happening immediately after installing the Forge CAI.
Theories? Does anyone else with a CAI notice this?
HiDo they sound good sarah and do they affect the performance at all?
If you dump some air, you'll be running rich, not lean...It has a diverter valve, instead of venting excess boost to atmosphere (for pssst) it returns it. You can add the Forge spacer which vents and makes that noise, but the amount of air in the system is metered - so if you vent some air the car will be running lean for a little bit every time you vent (ie change gears)
