1.8L P AEB
95-99
K03
K
5303-970-0005
058145703L
150 bhp
£388.00
i want a ko3s tho... would that be this 1???
listed for a A3..
1.8L P AQA
98-01
K03
K
5303-970-0026/35
06A145704A/B
180 bhp
£357.00
Yeah, think the exhaust turbine is bigger.. needs a bigger housing/manifold. I could be wrong though.
Doesnt the turbo simply bolt to the manifold? the Longitudinal K03's dont have combined manifold/turbine housing assys like some of the other fitments so the larger turbine shouldnt matter as the housing will come with the new turbo?
Unless they changed the mounting flange, but i kinda doubt that?
You can have the one off the left hand side of my engine. The way I see it, if I run with only one turbo, on the right hand side, I should save some money on petrol....
many thanks to dappadan786 seems my turbo problems will be sorted come this weekend!
thanks again dude!
no probs fella, happy to help you out.
Just looked at your Sig and you have all the bit's on with a custom remap yet you have not started a thread with your results
hi Doc, its ben bad experiences after another! things just went wrong from when i placed that large order with ECS Tuning, i had 3 lots of faulty flywheels sent. when the correct was finally sent. i had boost leaks due to having the wrong pipes sent with the intercooler! then found a leak in the ATP exhaust manifold.
ive barely had anytime to sort it out and its kinda sat there. ive got the car opened up im replacing all gaskets(exhaust mani, inlet mani, rocker) just replaced the crank breathercase pipes inc the T pipe and checking over any other Vacuum pipes.
also getting misfire under boost, at moment nothings showing up on VAGCOM. so im gonna replace the cheapest items first. crankshaft sensor, ignition control module and last coilpacks!
its been a bumpy ride but im hoping to get there soon, im doing all the work myself at the moment with limited time.
Dan
who supplies turbos without turbine housings?
