Hi everyone,
Just had the S3 on Vagcom to turn the engine management light off.
(comes on every few hundred miles, believe this is caused by too many spikes in power due to remap and the ECU getting grumpy about it, so ECU reverts to the backup map and turns the engine management light on).
Anyways I've got 8 codes altogether no:eeeek) but I'm concentrating on 2 in particular for the time being as they both mention the N249 valve.
The codes are
http://wiki.ross-tech.com/index.php/17705
17705 Pressure Drop between Turbo and Throttle Valve (check D.V.!)
http://wiki.ross-tech.com/index.php/17608/P1200/004608
17608 Boost Pressure Control Valve (N249): Mechanical Malfunction
Its been suggested that I get a system pressure check to see whats going on which I think sounds like a plan. Also just to let you know the S3 has an Apexi AVCR hooked up to it, and I've been told this may be causing problems too.
Has anyone else had these codes or similar issues with the N249 valve or Apexi AVCR unit? If so what did it take to get things sorted?
Cheers,
Chris
The codes are
Cheers,
Chris
