Bought an H&R ARBS kit and am going to fit them this weekend...
any other parts I need to change while I'm at it?
As mentioned, do the rear first. Your car will handle great with it even if you don't have time for the front.
Front isn't too bad when you get into it. Undo :
ARB ends and bolts that hold the steering rack to the subframe. Dog bone mount to gearbox. Then the four main bolts that hold the subframe to the chassis. I recommend purchasing a black impact socket. They have stress relievers on the flats and take more torque. I broke to normal sockets re tightening to the correct torque on mine. They are cheap from a motor factor.
You don't need to undo the ball ball joints and you can let the subframe hang enough to get at the ARB. You might need to lever the rack of the subframe a little, but they aren't that tight.
If its a bit cramped, then remove the last few bolts and drop the subframe out leaving the rack in place.
I've probably forgotten something. I'm sure others will step in if so.
ah ok, got it now...so mine is definitely adjustable..will need to look for the endlinks
I also read about the H&R clamps not being the best
http://forums.vwvortex.com/zerothread?id=3138043
http://forums.vwvortex.com/zerothread?id=2388065&page=1]
BTW, do you get the fittings when you by the eibach ARB kit?
Yeah, the Eibahc comes with EVERYTHING.
Abdus - get yourself a Walbro 255 or 4 bar in tank fuel pump.
Prawn and I recently found out they are needed for decent figures on the K03s upgrade if you have a higher mileage car (and therefore old fuel pump)
The one prawn and I have is now £200 on eBay................
