must be a ford thingAky said:My mate in his Cossie leaves it 5 minutes to warm up before driving and 5 mins to cool down - ****** to that!
Aky said:as soon as the temp hits 90 degrees its a green light. It takes me 30 seconds to get down my drive way so at a crawling pace and without boost then I think that will suffice. My mate in his Cossie leaves it 5 minutes to warm up before driving and 5 mins to cool down - ****** to that!
S3 NIK said:Isn't that just the water temp.
Oil is preserving the turbo and as far as i know oil takes longer to reach its optimum working temperature than it takes the water to hit 90 degrees.
I could be wrong though........
Nik.
Ballcrusher said:5mins worm up then no higher than 3000rpm till temp its 90 then on cool down hit the turbo timer
joshW said:my sound silly to some but what does a turbo timer actually do? and is it worth purchasing?
josh
joe6886 said:I thought the BAM engined ones had a system on that runs oil through the turbo for a couple of minutes anyway when you have switched the car off?
joe6886 said:I'm pretty sure they do, I wouldn't imagine the same on your Golf though as there is no turbo to cool down.
