A4 1.9 PD TDI 130 loosing coolant
Jacko1
Hello ,
A4 1.9 PD TDI 130 loosing coolant , no obvious external leaks from hoses etc , no mayo in the oil -
strange additional symptom is that internal cabin vents red hot on passenger side and cold on driver side when calling for cabin cooling.
Possibly a blockage somewhere ? water pump failure ? should I start with a sniff test ?
Anyone have any ideas?
Hello ,
Have you checked the flange at the rear of the engine? I was losing coolant at one point and it turned out to have a hairline crack in it as it's plastic
Flange can warp over time with heat cycles. Plenty of ebay. So its worth inspecting it just in case.
