lolI'm just looking at that picture and can see what it takes to remove it...
That's what Haynes says as well but I can't see any obvious bolt to undo.if you still need to remove it Its secured by a bolt at the front (bottom) which needs to be undone.
This black part covers the brake fluid reservoir, can it be easily removed?
It just makes it awkward to see the fluid level in the reservoir.
I've already removed the beauty plastic cover that fits on top of the engine.
Level sensor sits on the cap not the cover... it can be removed without a problem.see the picture of the cap loosen that torn screw and it can be removed once you u clip the other parts... it's not rocket science.It probably can be removed, but the cap has an electronic level sensor so the car will tell you when it's low.
