Found the issue with my DAB reception (hopefully) any idea for reconnecting these connections to the window aerial? Wary of getting the soldering iron out in case I burn the aerial out, perhaps i’m better fitting an aftermarket aerial
They would probably write the car off lolOops a stone flicked up of the road & smashed my glass..........
When the new amp arrives i'll give it a go, failing that its new window time unless I can work out a shark fin type solutionThe tracks would probably burn out, it's so thin it's almost impossible to repair these once the pads have snapped of.
Certainly ask the question as it's free, but I'm not positive it will be possible.
Awesome I was wondering what that antenna did! Taht could save a lot of hasssle thanks i'll give that a bash and updateIf you have an Avant the TV antenna connections are in the other side of the rear quarter glass on the C pillar. The solder pads are on the glass but no wires connected. Wires are connected in the same sequence black, yellow, red when viewed from the top. There is also a mounting point for the antenna amp. Might be worth a try to see if it restores reception, if it works move the DAB amp and get a short Fakra extension to link to the original DAB cable.
Ah apologies i'm with you now i'll pull that trim off and check for that today, cheers!
You sir are a legend! Fitted the new dab amp and connected to the TV aerial and it works better than ever! Iowe you a few pints for that bud thanks very much!Ah apologies i'm with you now i'll pull that trim off and check for that today, cheers!
Where do you live bud? I'm due you beers! I ran a 3 core cable from the TV antenna round to the existing location for the DAB amp to keep it where it should be. Great fix and soldering onto the blobs of solder on the TV side was easy enough. If Carlsberg made diy repairs hahaWas the coaxial cable long enough or did you extend the 3 single wires.
