Abs sensor
Daniel Evans
Age
31
Warwickshire
Hi all, recently changed my faulty abs sensor and I’m still getting the light come on, does anybody know if I need to plug it in anc clear the code or?
Have you checked the stator on the hub, mine was corroded and had to change both, it will need resetting too from what I can remember
Yeah tha looks
yeah that looked fine to be honest, but still coming up with code
As above I had to change both as it had swollen
Reactions: Daniel Evans
Was the tip of the oldsensor damaged at all?
This was mine
It might have been yeah
If the tip was damaged then the likely cause would be corrosion on the ABS stator as the gap between the two is only millimetres
My hub/stator
Reactions: samisnake
4K
732
8K
