2019 Audi A8
I googled a lot but don't really understand so any help would be appreciated. None of these will clear even with bonnet up as advised on Ross site
Address 09: Cent. Elect. (J519) Labels:* 4N0-907-063-V2.clb
Part No SW: 4N0 907 063 DE HW: 4N0 907 063 AE
Component: BCM1 MLBevo H10 0652
Coding: 07500143C13900CD070E87081FEF8C68131BB3110406009381000A00000196800845010200100000000001000005001B100200304001F107000000000000000000
Shop #: WSC 02391 785 00200
ASAM Dataset: EV_BCM1BOSCHAU651 014010
ROD: EV_BCM1BOSCHAU651_014.rod
VCID: 74B1CFB01E314FCBFFA-8020
Wiper motor control module:
Subsystem 1 - Part No SW: 4N2 955 119 HW: 4N2 955 119
Component: WWS651 181010 052 0915
Serial number: 904753F0301828302796
Coding: 7DC727
Rain/Light Recognition Sensor:
Subsystem 2 - Part No SW: 81A 955 555 A HW: 81A 955 555
Component: G397_RLFSS H06 0002
Serial number: 22301989X81A955555A0
Coding: 02005E
Light switch:
Subsystem 3 - Part No SW: 4N2 941 501 B HW: 4N2 941 501 B
Component: E1 - LTM H05 0053
Serial number: 18S17.04.1800300161
Automatic dimming interior mirror:
Subsystem 4 - Part No SW: 8W0 857 511 HW: 8W0 857 511
Component: Y7_Innenspieg H09 0002
Serial number: GX1CE105101823610098
Coding: 210000
Interior Light Module:
Subsystem 5 - Part No SW: 4N0 947 135 CE HW: 4N0 947 135 CE
Component: Dachelektroni H42 0063
Serial number: 00000316700000000000
Coding: 100000
Adjustable Steering Column Control Module:
Subsystem 6 - Part No SW: 80A 907 705 HW: 80A 907 705
Component: J866-EVLS-SG H03 0100
Serial number: WA135527000060007727
Coding: 0A0700
Blower 1 for left front backrest:
Subsystem 7 - Part No SW: 4N0 963 575 HW: 4N0 963 575
Component: V512 LLR1SLvL H01 0012
Serial number: Q98AJ00220353
Blower 1 for left front seat cushion:
Subsystem 8 - Part No SW: 4N0 963 575 HW: 4N0 963 575
Component: V514 LLR1SKvL H01 0012
Serial number: Q98AI33854472
Blower 1 for right front backrest:
Subsystem 9 - Part No SW: 4N0 963 575 HW: 4N0 963 575
Component: V516 LLR1SLvR H01 0012
Serial number: Q98AJ00220354
Blower 1 for right front seat cushion:
Subsystem 10 - Part No SW: 4N0 963 575 HW: 4N0 963 575
Component: V518 LLR1SKvR H01 0012
Serial number: Q98AI33884875
Front windshield washer pump:
Subsystem 11 - Part No SW: 4N0 907 605 B HW: 4N0 907 605
Component: J1100/SWP H21 0015
Serial number: 00000000001835201468
Coding: 020000
Interior Light Module 2:
Subsystem 12 - Part No SW: 4N0 947 111 D HW: 4N0 947 111 D
Component: Dachelektroni H42 0060
Serial number: 00000317930000000000
1 Fault Found:
405507 - Functional Limitation due to Energy Management
B10CD 00 [009] - -
[Function limitation due to energy management system]
Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 6
Fault Frequency: 1
Reset counter: 11
Mileage: 117460 km
Date: 2023.02.03
Time: 22:10:53
average_Voltage_terminals: 11.40 V
Outside air temperature sensor-Resistance: 0.00 kOhm
Outside air temperature sensor-Outside air temperature on CAN: 8.50 °C
interior_temperature: 13.00 °C
Vehicle speed: 0.00 km/h
Terminal activation-Terminal 75 status: On
Terminal activation-Terminal 15 status signal: On
Terminal activation-Terminal 15 via CAN: On
Terminal activation-Term 75: qualification: OFF
Address 19: CAN Gateway (J533) Labels:* None
Part No SW: 4N2 907 468 AL HW: 4N2 907 468 AB
Component: Gateway H14 0044
Revision: AB000002 Serial number: 028AB791618C21
Coding: 020100050004864073960000005B01325C98004018000000097D078E10000000
GVL: F1513C080844000002FC88000000C800110E0010000000000000000000000000
ASAM Dataset: EV_CGateCONTIAU491 003170
ROD: EV_CGateCONTIAU491_003_AU58.rod
VCID: 03539C6C4B9F7873F60-8056
Multifunction steering wheel control module:
Subsystem 1 - Part No SW: 4N0 951 523 J HW: 4N0 951 523 J
Component: E221__MFL H06 0003
Serial number: 00000000000000000000
Battery Monitoring Control Module:
Subsystem 2 - Part No SW: 4N0 915 181 A HW: 4N0 915 181 A
Component: J367-BDMConti H03 1050
Serial number: 7588540300190107001D
1 Fault Found:
8519683 - Energy Management Active
U140B 00 [009] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 11
Mileage: 117460 km
Date: 2023.02.03
Time: 22:10:43
EM_vehicle_state: 02 1C
Static current shut-off stage: Deactivation stage 1
Auxiliary heater activation restriction request-Parking heater: Permitted
Auxiliary heater activation restriction request-Allowed parking heater runtime: 0 min
Address 5F: Information Electr. (J794) Labels:| 4G1-035-MIB-HGH2.clb
Part No SW: 4K0 035 064 D HW: 4K0 035 064 A
Component: MU-H-LN-EU 046 2711
Coding: 0156010100000000C3110002000800302F0001E603F008008E
ASAM Dataset: EV_MUHigGen2pALPI 001001
ROD: EV_MUHigGen2pALPI_AU27.rod
VCID: 2517E2F4E56B6643B84-8070
Data carrier:
Subsystem 1 - Part No: V03 959 807 SF
Component: MIB2P_EU_Q121 0520
Multimedia System 1:
Subsystem 2 - Part No SW: 4N0 919 605 G HW: 4N0 919 605 C
Component: DU AU651 Top H43 0147
Serial number: INX00120101800040309
Compact disc data bank:
Subsystem 3 - Part No: V03 959 800 EG
Component: Gracenote2 1009
Volume Control 1:
Subsystem 4 - Part No SW: 4N1 919 616 B HW: 4N1 919 616
Component: LSR-D5/C8 H33 0110
Serial number: 00004418000247420043
Multimedia System 5:
Subsystem 5 - Part No SW: 4N0 919 603 C HW: 4N0 919 603
Component: DU AU651 Bot H41 0147
Serial number: INX00112101800050779
Media Player 1:
Subsystem 6 - Part No SW: 4N0 035 123 HW: 4N0 035 123
Component: DISC PLAYER H06 0006
Serial number: AUZ8ZCJKJ00MQM0
Media socket:
Subsystem 7 - Part No SW: 4N0 035 736 A HW: 4N0 035 736
Component: MediaConnectH 014 0133
Serial number: 051800786695012
1 Fault Found:
1555 - Check Software Version Management
B201A 00 [009] - -
[Check software version management]
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 11
Mileage: 117460 km
Date: 2023.02.03
Time: 22:10:49
Voltage terminal 30: 11.5 V
Status_Software_Version_Management-module_name: zFAS_Var_C_CL020
Address CD: Laser Scanner (J1122) Labels: None
Part No SW: 4K8 907 660 B HW: 4N0 907 660
Component: LASER_SCANNER H36 0202
Shop #: WSC 00000 000 00000
ASAM Dataset: EV_LaserScannAU651 013013
ROD: EV_LaserScannAU651_013.rod
VCID: 353732B455CB16C3084-8060
1 Fault Found:
11546627 - Laser for Adaptive Cruise
C12EB F1 [009] - Malfunction
[Heater_Resistance_too_high_error]
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 11
Mileage: 117460 km
Date: 2023.02.03
Time: 22:10:47
Control Module temperature-Host: external temperature: 21 °C
Control Module temperature-Zynq: internal temperature: 37 °C
Control Module temperature-Host: internal temperature: 21 °C
Control Module temperature-Zynq: external temperature: 18 °C
Voltage terminal 15: 11.317 V
heating_resistor: 90.59 Ohm
heater-Medium power: 0.000 W
heater-Voltage: 0.000 V
heater-PWM value: 0 %
heater-Current draw (mean value): 0.000 A
Heating and cleaning management-Visibility: 0 %
Heating and cleaning management-Degree of contamination: 9 %
Heating and cleaning management-Heating status: 02
Heating and cleaning management-Cleaning status: 02
Outside temperature: 8 °C
Coding: 7DC727
Coding: 02005E
Light switch:
Coding: 210000
Coding: 100000
Coding: 0A0700
Coding: 020000
1 Fault Found:
B10CD 00 [009] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 11
Mileage: 117460 km
Date: 2023.02.03
Time: 22:10:53
1 Fault Found:
U140B 00 [009] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 11
Mileage: 117460 km
Date: 2023.02.03
Time: 22:10:43
Data carrier:
Volume Control 1:
Media Player 1:
Media socket:
1 Fault Found:
B201A 00 [009] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 11
Mileage: 117460 km
Date: 2023.02.03
Time: 22:10:49
1 Fault Found:
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 11
Mileage: 117460 km
Date: 2023.02.03
Time: 22:10:47
