Anyone able to successfully delete the exhaust valve module?
Looking for custom exhaust options.Why ?
I seen you were testing out those exhaust valve delete/bypass plugs a while back.
When it gave you the error codes, did it leave any hard codes stored in the system? That could be detected from Audi at a later stage?
More Audi 'scared sh+tless of anything emission related' cr*p, *** it's an exhaust valve, hardly crime of the centuryIf you unplug the valves it leaves errors I’m afraid.
You will then struggle to clear them unless you have VCP and a way to unlock SFD protection.
Reason i was asking, here in South Africa they make custom exhausts 99% of the time instead of importing because of costing, and for the downpipes for RS3 8y they use a OBD automatic fault code clearer that stays plugged in to avoid limp mode and dash lights.If you unplug the valves it leaves errors I’m afraid.
Do you think if you unbolt the exhaust valve servo motors, but leave it plugged in so the car still recognizes the motor working, and just tuck it in somewhere at the back. Then you can change the rear box to anything you want with the car still recognizing a servo motor being connected. Its an idea which im not sure will work.
Servo motor is part number: 8S0133246D
If you want to google for reference
This will clear adaptation too, sounds as a bad solution.for the downpipes for RS3 8y they use a OBD automatic fault code clearer that stays plugged in to avoid limp mode and dash lights.
I have seen that ‘most’ companies world wide that offer catless downpipes use this as their solution though?This will clear adaptation too, sounds as a bad solution.
From what I understand the motor is looking for the increase in drawn current to detect when fully closed or open, when it doesnt see this, it flags up a fault. However I did read a while ago that someone attached the motor to a small fixture with stops perse that replicated the motor moving the flap as such, tucked it up out they way and all was good.Reason i was asking, here in South Africa they make custom exhausts 99% of the time instead of importing because of costing, and for the downpipes for RS3 8y they use a OBD automatic fault code clearer that stays plugged in to avoid limp mode and dash lights.
