which TIP?
abdus
Top Gear
On an Island
If going Forge/Samco you would need an AWW TIP with a blanking plug. That is assuming you have an AGU engine???
Otherwise the standard TIP for K03s will be fine, and preferable to paying silly money for a Neuspeed one.
It is the late K03 TIP that is restrictive, and the early K03s TIP's. A later, slightly wider K03s is fine and utilises the original rubber hose. You will not collapse the hose at the moderate pressures (20ish PSI) that will be produced from a K03s custom map.
I have pictures somewhere, comparing Forge to late K03s and early K03.
You can get a K03s TIP that attached to your rubber hose for about £20
