Gtech
Hi There, I have a S3 with APY engine with strange issues.
Little background info, when I got the car I found a lot of issues with the engine.
-MAF sensor was turned 180 degrees (yes I'm not kidding)
-Intake turbo hose hanging loose, fixed it.
-Changed boost actuator into newer revision
-Placed OEM diverter valve since the aftermarket spring was weaker then the original.
-Changed broken vacuum hoses
-Only fault code left is secondary air pump solenoid but that's not relevant for the issue.
-N249 and N112 systems are bypassed by previous owner/tuner
I also found a dynograph in the car so we found out it has stage1 tuning map from 'ziptuning'
Now the last issue that I cannot resolve, the car is running OK now but for our yearly check MOT/APK we need to have a working emission system (lambda and katalysator.)
Since the catalysator was missing I placed a new one and is working. Also the lambda sensor wasn't working as it suppose to do so I changed that also. (afterwards I tested the old lambda sensor but it was actually working properly)
Only the strange thing is it seems that the engine is not using it's lambda input. Almost looks like the engine is running open loop and don't use it's lambda input at all. I tried unplugging the lambda and feed the ecu 0V to see if it responds but no change in exhaust readings.
So I called the tuner and ask if they removed the lambda parameters when they tuned the car and they say they never do that. They could bring the car back to original but they don't think it will fix my issue. Could my engine ECU be broken? What do you guy's think how to tackle this? How to check or restore the engine lambda settings?
Thanks for reading my story.
