Advice taken.
The following went well in the sun shine today
Oil pump. Chain, Tensioner. Cam belt , cam tensioner, cam idler, water pump, Crank shaft seal
Oil and filter
Hoping that all is still healthy with S3,
After priming oil, we fire her up.
Sounding OK, but straight away whilst listening to her idle I new that the broken oil pump tensioner was not the main culprit.
an uneasy rattle type noise, not a bent rod or small or big end.
like a cam knock? but knock was not under load.
Maybe turbo bearing failure, I was thinking.....
I want to upgrade engine but was not ready for it now, I got too much on at mo...
Plan to take I-ECU log to see if any comes up tomorrow.
Else
Engine out and total rebuild, with bigger turbo and get to fit rods and pistons already gathering dust.
Will take I-ecu log to see what data is recorded and a video to hopefully capture the intensity of the noise after deacceleration tomorrow.
Found this on the group, thought this best sounded like my problem.
If it is, what are the best options available for car.
Thanks Tuffy
Badger 5 Edition...Its all about the flow...
VVT has two effective positions only... the code relates to the ECU trying to advance the cam and not detecting the advance in a timely fashion..
VVT is oil pressure driven... wear of the piston and the pads is subjective so cannot predict a mileage...
Symptoms of a 'failing' VVT range from throwing this code to a brrrraaat noise noise as the VVT drops back into its normal position coming off the revs... normally around 2000 rpm...
Complete failure can range from the code to a very very bad rattle is the pads fall to bits..
In my experience this code means the VVT needs replacing... simple as that..
